- This topic has 22 replies, 16 voices, and was last updated 15 years, 2 months ago by
37monkey.
June 26, 2011 at 11:33 am #13704
Cooks
I’ve just had an utter heart-in-my-mouth moment during a 35mph speed wobble. Are there any tricks to avoiding these wobble? why do they happen? Or am I wrong is it even a speed wobble that I had? All I know is that I was coming down a hill and my front end started to go. Managed to correct it by slowly braking, but bloody hell did it scare me.
37monkey
cborrman wrote:
3) are
[quote=cborrman]
3) are obsessed with slicks and weight alone, a bit of tread is a good thing!:/ tread may be good for off road but with a contact area about the size of a penny (ish) the last thing I would want is bits missing from my road tyre, even in the wet there is enough capillary action from the road surface to remove water – and that’s the only reason tread is needed, moto gp and f1 prove this. perhaps a compound with more grip would be better advice in this situation? imho
oldgit
Just remembered. I had it
Just remembered. I had it once very badly and all it was was two loose spokes. When they were about to come out the whole frame started to fishtail.handlebarcam
Swapping my forks for a
Swapping my forks for a stiffer, heavier, straight-bladed model worked for me. But I was sure there were no defective or misaligned parts, and doing the same may have no effect for you.Cooks
No I wasn’t braking, just
No I wasn’t braking, just descending. Having read some of these links, putting my knees on the toptube seems to be the way to go, whereas stiffening up, gripping tighter and making my peace with God like I did is prob no the best way to correct it. I think I’ll prob be able to sort it next time, I’ll give my hubs a thorough going over in the meantime.Posh
The only corrective measure
The only corrective measure when it happens is to grip the top tube with your legs. Helps dampen the oscillations.I assume you weren’t braking were you? I’ve suffered severe judder when braking at about 30mph. Scares the c–p out of you. The cause was a build up of brake rubber on the rim. Good clean of the rim and blocks – no further problems.
arrieredupeleton
One theory is front end
One theory is front end stiffness :O I know people in the past have swapped forks to a stiffer one and this has solved things. I havent read the link but presume you know about the gripping the top tube with your legs thing?vorsprung
Only time I got a death
Only time I got a death shimmy ( at 75kph ) it turned out later that the bike had a crack around the seat tube/top tube joinI guess this helped it to be less rigid and so more prone to vibration
dave atkinson
maybe you could attach
maybe you could attach fishing leads to the spokes 🙂cat1commuter
Having read a couple of the
Having read a couple of the links, getting more weight over the front wheel sounds like a good idea.cat1commuter
dave_atkinson wrote:If you do
dave_atkinson wrote:If you do have an unbalanced wheel, then you can balance it by weighting it like you would a car wheel. a bit of extra inner tube inside the tyre can be enough to balance things out.On my front wheel I find that the lightest point is the valve. ie: If I leave the wheel to spin freely, it stops with the valve at the top. I tried screwing some extra nuts onto the valve, but they weren’t heavy enough. Would be nice to have some lead doughnuts that fit over the valve to balance the wheel.
cborrman
as many say above, it should
as many say above, it should not happen at that speed!My first suspicion is always spoke tension, you would be amazed what a difference it can make. many shops are obsessed with the wheel being perfectly true (which is a huge step above not giving a sh@t if its less than 2mm out!) rather than even tension, fortunately my latest LBS has a physics genius in the workshop and understands that even tension is the key, even if that means the wheel being slightly out, to avoid a myriad of sins, including wobble.
anyway, technical probs aside, which you no doubt have to get a wobble at that speed, to be able to help get yourself out of these and other problems when this happens, in mountainbike world we put a bigger/grippier tyre and/or run less pressure on the front, so the rear should be telling you that you are on the edge before the front does, and is easier to correct a rear slipping than the front. In road world this translates to running 5-10 psi less in the front and or 5/10psi more out back (all other things being equal. ie if you are already running way too little or way too high a pressure in your tyres then 5psi is not going to make a diffierence)
the biggest problem is that in road world a lot of people do the following:
1) run way too much pressure in both tyres: no way out of a wobble: 5/10 psi meams sod all if you are already 20/30psi too high!
2) put a thinner tyre on the front, less grippy tyre at the front, swap a skidded out rear for the front, etc
4) never ride a mountain bike – there is no better way to learn wobble recovery than hacking it on a mountain bike and managing squirm, wobble, traction loss, etc at least once a week/month
sermon over, get your wheels/hubs checked 🙂
The Weekly Cycle
Hi, there are plenty of
Hi, there are plenty of things that cause speed wobble. For a good article on the topic, read this; http://www.cyclingtipsblog.com/2011/03/speed-wobble-when-the-bike-shakes-its-head/Gkam84
If youdave_atkinson wrote:If you do have an unbalanced wheel, then you can balance it by weighting it like you would a car wheel. a bit of extra inner tube inside the tyre can be enough to balance things out.
I never thought of using inner tube, i did an “old skool” scalextric trick that used to weight the back of the car down a bit, a lump of blue tack 🙂
Cooks
I have but on a different,
I have but on a different, heavier bike. Plus I had a bit of extra poundage myself. I’ll buy the resonant frequency theory, sounds good and sciencey…stewieatb
I’m familiar with speed
I’m familiar with speed wobbles on 4 wheeled boards – longboards and mountainboards – but on 2 wheels it’s a different phenomenon. It could be, as Dave suggested, a slightly misbalanced wheel, or something in the road surface resonating with some part of the bike geometry (this seems more likely – have you done that descent at that speed before?) -
