- This topic has 8 replies, 5 voices, and was last updated 15 years, 8 months ago by .
Hey y’all, how ya doin?
So, I’m having trouble with my SRAM Rival front shifter. I’m setting the inner cage travel, then tensioning my cable. Now when I shift to the big ring, I’m not having to touch the high limit travel, because the chain is touching the outer plate of the derailleur. A bit of screwing on the low limit fixes this, but not to the point when I can use my higher gears, as the chain still rubs on the cage. Also, this sometimes prevents me from shifting down to the smaller ring succesfully. I’ve found a (kinda) happy medium, but this means I can’t use all of my gears successfully.If you know what I’m going on about, that’d be a good start. Has anyone else had any trouble? I’m also really having to wrench my front shifter to shift to the big ring.
Any help would be great, if you can fathom what I’m on about….!
