- This topic has 0 replies, 1 voice, and was last updated 15 years, 10 months ago by .
Brand New, Boxed felt b2 pro. RRP £4500+. 54cm size, these sell out quickest so you wont find these on sale very often.
Spec as below
• Finish – Gloss White/Carbon
• Sizes – 50, 52, 54, 56, 58cm
• Frame – Felt Tri Specific UHM Ultra-high Modulus Modular Carbon Fibre Frame with 3KP Finish, Full Aero Tubeset with front & rear wheel recesses, internal cable routing, forged horizontal dropouts
• Fork – Bayonet II UHM Carbon Fibre Monocoque Design with 3KP Finish, Carbon Blades, Dropouts, Crown & External Steerer with Felt 1 Bearing Compression Device
• Headset – Bayonet 1 Integrated
• Stem – Bayonet II Integrated CNC Machined Aluminium, Rise, -35° thru +43°
• Handlebar – Felt Bayonet UHC-Nano Carbon Fibre 420mm Base Bar
• Grips – Tri-tip Ergonomic Base Bar grip with Felt Gel Ribbon Cork Tape with Felt 3D Logo wrapped extensions
• Shifters – SRAM Aero Double Tap 20 speed Bar End Shifter
• Front Derailleur – SRAM Red braze-on, double
• Rear Derailleur – SRAM RED short cage with ceramic bearing pulleys
• Crankset – SRAM RED GXP, 53/39T
• Bottom Bracket – SRAM compatible External 68mm
• Chain – SRAM 10 speed with PowerLock
• Freewheel- SRAM OG-1070 Cassette
• Brake Levers – SRAM Brake Levers with carbon fiber blades
• Brakes – SRAM RED Dual Pivot
• Cables – Slick Brake & Derailleur
• Saddle – 3.1 Team Issue Tri/TT Saddle
• Seat Post – 3.1 UHM Carbon Fibre Bladed Monocoque Design x 300mm
• Seat Post Clamp – Aero 3D Forged Aluminium, 2x5mmx0.8mm Cr-Mo Bolts, 18 Grams
• Rims – 700c: Front Wheel Zipp 404,16H, Rear Wheel Zipp 808, 20H; All Clincher – custom b2 pro wheelset
• Front Hub – Zipp 16H Front hub with Grade 5 steel cartridge bearings
• Rear Hub – Zipp 20H Rear Hub with Grade 5 Steel Cartridge Bearings, Shimano Compatible Freehub
• Spokes – Sapim CX ray spokes laced radial FRONT/Laced 2x non drive radial drive REAR
• Tires – Vittoria Diamante Pro-Light Kevlar Bead Folding 700x23cWas £4500, asking £3300 ono
Full warranty.
