Electric Vehicles – Red Herring?
  • This topic has 47 replies, 22 voices, and was last updated 7 years ago by Bmblbzzz.
Viewing 15 replies - 1 through 15 (of 47 total)
  • #952775
    Bmblbzzz
    The answer to the problems
    The answer to the problems caused by too many cars can never be “different cars”.
    #952773
    OldRidgeback
    vonhelmet wrote:
    vonhelmet wrote:
    The most economical and ecological thing you can do car wise is run an old reliable car into the ground. The carbon footprint of manufacturing an old car is a sunk cost, so all you have to deal with is the marginal impact of repairs and miles. The impact of manufacturing new cars is vast. What’s the impact of mining all that lithium compared to running an old Volvo (other reliable cars are available) to 200,000 miles? It’s almost like the car industry is more concerned with selling new cars without regard to their actual lifetime environmental impact.
    Better still if you convert it to run on LPG. No particulates at all, and a lot less NOx.
    There’s a lot to be said for having an old SII or SIII Landrover actually as they can be rebuilt repeatedly (aluminium body panels and a chassis that’s easily welded), especially if you run it on LPG.
    A big issue for EVs is how and where the minerals for the batteries come from. It’s all very well if the minerals come from a big mine in Western Australia with decent safety conditions and pay for the workforce, as well as legislation to prevent the worst environmental contanimation, quite different indeed if they’ve been sourced from an operation in Africa using child labour in horrendous condtions.
    #952771
    alansmurphy
    CXR94Di2 wrote:
    This is my Wife’s car heading to London having done over a 100 miles so far to visit an ill relative in hospital. She will probably do a quick top charge on the return leg, whilst having her lunch
    The journey in savings £7 electric overnight charging as opposed to £41 Petrol
    Zero CO2, NO2,  driving emissions 😀
    23 degrees, I’ve never been in a mobile sauna before!
    #952769
    kt26 wrote:
    CyclingInBeastMode wrote:
    Now if they were to knock out a Sinclair stylie vehicle similar to the one I pictured above Or the Iris E Trike, made it in the UK, made it free from all the weighty crud as the ETrike is (hence 55kg incl battery) that would change the balance of a viable/covered transport mode for up to 20-25 miles each way then that would smash the argument out of sight.
    Not made in the UK (Norway), but this is set to go into production next year:
    https://www.podbike.com/en/
    It looks alright but has over engineered wheels that are costly and weighty, I don’t want something that comes to me automatically/beck and call, that means more weight, more gadgetry/stuff to go wrong and simply isn’t needed, it’s a gimmick. I can’t say I like the gearless motor in the wheels, again, more unecessary weight and tech, a simple bike derailleur system would work just fine and is hugely adpatable/cheap.
    Also If we are to get people to move the medium range distances then we need to conider having a vehicle that can go faster than 16mph under its own power, that’s why something like the Iris Etrike would be more preferable at 25mph and yes if you are to have this option (or even faster) then requiring insurance etc
    I do like that it has luggage/child seat option however, that is the one big plus over the Etrike, another thing to save weight/cost would be fabrics as the exterior instead of polycarbonates.
    All the problems are that none of them including the podbike (or podride from Sweden) are currently actually selling models. I was interested initially in the IRIS Etrike by Sinclair but it simply didn’t look like people were going to get anything for their money and production dates have been pushed back years and there has so far been no actual models handed out though a test ride by an ‘early bird’ investor occured in May nothing else has happened.
    #952767
    Rich_cb
    Griff500 wrote:
    Griff500 wrote:
    You’ve missed the point. The peak wind speed acceding to the paper YOU referenced is not where you said it is. You said the peak was between 18:00 and 20:00. It isn’t for any of the 3 years the paper discusses. 2 of the years peak at 14:30. The 3rd at 17:00. YOUR data does not support YOUR argument, not even 2013. The peak of your graph is not where you said it is. Learn to read a graph, then your argument may have more credibility.
    The point was, and remains, that EV charging is best done at night. That was the entire basis of this discussion in the first place. Whether the peak is at 1700 or 1800 doesn’t change that.
    #952765
    Griff500
    Rich_cb wrote:
    Rich_cb wrote:
    Griff500 wrote:
    Yet your own referenced data shows that wind output peaks in late afternoon (17:00) in the UK, is well past peak by the supposed start of your “18:00 – 20:00” peak, and these “night peaks” of which you speak are a red herring.
    Having said that, even your own referenced data from a researcher at Strathclyde Uni, and averaged over a year, differs markedly from a more comprehensive 34 years worth of data published by Oxford, and which accounts for seasonal variation (your reference admits to this omission) which you will find here. https://www.eci.ox.ac.uk/publications/downloads/sinden06-windresource.pdf
    And which shows the daily peak at 14:00 for most of the year, and typically has dropped by 1/3 by your supposed “18:00 – 20:00” peak!
    This is actually quite convenient as UK electricity consumption peaks in late afternoon, just as wind is at its peak, and is at a minimum in early morning (4:00) when wind output is at a minimum.
    OK, so why the difference between the Strathclyde data and the Oxford data ? Well the answer is in your own paper. Your paper shows data for 3 different years, 2011, 12 and 13. 2013 is clearly different. The 2011 and 2012 data from your own paper fits closely with the Oxford 34 year average, showing peak at 14:30, and significant evening drop off. It is the 2013 data, which shows unrepresentative  evening performance (by the standards of the 3 datasets presented) which you chose to illustrate a bogus point. Andy even then, you misrepresented the time of the peak. Pretty shabby!
    Your paper looks at onshore wind speed. The data I referenced looks at overall wind power.
    Given that most new wind capacity is now built offshore your data is not necessarily relevant.
    The peak time for wind power varies considerably between regions so it seems reasonable that it would also vary between an onshore measuring point and a distant off shore wind farm.
    As off shore capacity is being added rapidly it may be that the 2013 data represents a shift in peak generation time caused by new off shore capacity or it may be a blip.
    Either way it doesn’t change the fundamental point that night time EV charging is less CO2 intensive than day time charging.
    #952763
    Rich_cb
    #952761
    CXR94Di2
    hobbeldehoy wrote:
    hobbeldehoy wrote:
    CXR94Di2 wrote:
    ICE cars clearly have their advantages at present but personally the local pollution created by them is the reason I couldn’t justify buying another one. If I buy another car it will be an EV.
    The only advantage is ability to drive 300-500miles without stopping.
    But lets look how most folk drive.  I would not drive more than 200-250miles non stop.  Its approx 4-6hours of non stop driving. That is not recommended for being alert to driving requirements.
    Some will say, but you can refuel in 5 mins and be on your way.  True, but on a long journey, one or more stops are for rest. food, toilet breaks.  This is where ‘rapid/supercharging’ comes in allowing the EV to recharge to 80/90% capacity in 30-60mins. negating virtually all extra time to recharge.
    Charge whilst eating/resting etc.
    Long journeys like that are few and far between.  the vast majority (95%) of journeys per day in the western world are 35 miles per day.  EVs are perfect for local commuter type trips.
    What is criminal,  75% of vehicle journeys are less than 2 miles per day!
    Polluting to take you kid to school or go to supermarket.  Walk or cycle if its only 2 miles
    The irony of this for me personally is that while car owners make lots of short and unnecessary journeys in the car, by comparison my car usage is completely different. My car can sit for weeks unused, I walk to local shops for groceries but when I do use it I tend to make journeys anywhere between 60 and 600 miles. Most of my journeys this year have been between 400 and 600 miles with a few 60 mile runs for good measure.
    Where I live there are a lot of elderly car owners making short journeys and they are the ones who could benefit from an EV. Most of them I speak to don’t want an EV though, largely because EVs are outside their price range. There is no charging infrastructure where I live and I haven’t seen any move to improve this by the local authority.
    Where I live it is very cold much of the year and an EV would be highly impractical. As I said, my car sits around for weeks unused and an ICE car can handle this better than EV, Batteries don’t like cold. I wouldn’t be confident about going out to an EV sitting in the cold for weeks and expecting it to have a decent charge and so for me it would need constant charging even when not in use,
    This is putting aside the other impracticalities involved in long distance journeys with an EV. Making stops to recharge, high rates of discharge in winter due to using the heater, lights and blower.
    If you have a drive to park a car, then an EV home 7kw charger will do 99% of your usage. We dont have a supercharger or Chademo within 25 miles of our house. We rarely use rapid chargers. Most EVs have sophisticated battery management systems. These control level of charge so not to prematurely age the battery. You can leave them plugged in on trickle.
    Your own situation is a little unusual, so possibly an EV isnt for you. The majority just seem reluctant to embrace new-ish propulsion.
    #952759
    hobbeldehoy
    #952757
    Griff500
    Mungecrundle wrote:
    Regardless of how you feel personally about the suitability of an EV as a replacement for your own ICE powered car right now, EVs are here to stay.
    https://europe.autonews.com/sales-market/ev-sales-surge-uk-market-down-2-august
    Summary: Full EV now 3.4% of market share, increasing sales by 378% over the year to August 2019 against an overall drop in UK car sales of 1.6% in the same period.
    …..except that the underlying data from SMMT which the article references doesn’t support the conclusions of the article. Current data to October,  shows that full electric (BEV) only makes up 1.4% market share YTD. Overall change YTD is a still respectable 125%, but a long way short of the 378% you have quoted.
    By far the biggest percentage increase is non-plug in Diesel Hybrid vehicles, which has increased by 796% YTD.
    To add some context, the total sales of full electric (BEV) cars YTD is only 28,259, against a total of over 2 million cars.
    Hybrid cars, for anybody who wants to drag around 2 engines and 2 fuel sources, still vastly outsell full electric cars.
    So yes, the numbers are encouraging, but the article is telling porkies.
    #952755
    Mungecrundle
    Most of the big manufacturers are now commited to producing full electric models, representing investments in the $Billions.
    Government legislation in pursuit of self imposed pollution reduction targets may not go as far as some want, and go further than others are willing to accept but they are real and they are being enforced in jurisdictions globally.
    Many people in the UK currently in the fortunate position to buy an EV are able to charge it from their domestic power supply overnight on the driveway. Range is only a factor for a very small percentage of journeys and fast charger infrastructure is expanding. If needs must and you have the time, any 13amp socket is a potential fuel station.
    I’ll buy into the prospect of increased total EV mileage being matched by an increase in UK renewable energy. I’ll also buy into the potential of battery technology making technological advances in storage capacity, charging rates and recycling. You sort of have to have the economic necessity of one to justify investment in the other.
    None of this will take place overnight. I get the argument about holding on to older cars which are perfectly roadworthy rather than scrapping them, but eventually they will wear out, be that tomorrow or 20 years from now. At some point you will be looking to replacement and at that time you may have a choice of private ownership, shared ownership, public ownership or a complete change of lifestyle that avoids any motorised travel. What you will almost certainly have increasingly less choice over is to select an internal combustion engine option.
    If there is one huge question about EVs at the moment, it is how the government are going to make money from them in terms of replacing all that fuel excise duty and VAT on excise duty that they currently rake in.
    #952753
    Kendalred
    Dear Santa,
    If you’re listening, I have been a very good boy this year, and…
    I WANT ONE OF THESE!!!!!!!!!
    Edit: Okay – Christmas next year will do.
    #952749
    Griff500
    Rich_cb wrote:
    You’re wrong. …….
    Wind output in the UK is stronger in early evening/night peaking at about 1800-2000. Wind makes up a far larger share than solar (Which is obviously stronger in the day.) Wind capacity is growing rapidly so the evening/night peaks/
    #952751
    Philh68
    Thanks Griff, saved me going
    Thanks Griff, saved me going into detail. You can get live stats globally on electricitymap dot org which will confirm that too. It’s a handy reference to show which countries do and don’t make sense for EV.
    #952747
    CXR94Di2
