Cannondale Topstone Carbon – anyone else had any issues?
  • #30234
    Carax
    Hi All,
    Just wondering if there are any other Topstone users who have had issues with the bike.
    Firstly, the party trick, the Kingpin bolt came loose halfway through a ride. Chain stays had about 5 mm of play.
    Shop took it apart and tightened it, but that was about 2 weeks into ownership.
    Now, the rear freehub is broken. Not spinning at all, advised all bearings need replacing, etc etc.
    I mean the bike is about 9 weeks old and has been off the road due to these issues for about 4 of those weeks.
    Anyone else had similar problems with it? Or just me?
Viewing 15 replies - 1 through 15 (of 17 total)
  • #951791
    Carax
    Yes, that sounds like a
    Yes, that sounds like a terrible experience!
    #951789
    extrusion wrote:
    Yes, loads.
    Knocking from bottom bracket after a week, took to lbs who added a spacer. Still feels too loose to me but no more knocking.
    Persistent clicking noise from suspected headset and juddering of front brake,  sent back to dealer who helpfully tightened the headset cap that I had loosened for transport and claimed everything sorted. Clicking remained. Replaced stem, seemed better but would get worse as the day warmed up, replaced bars, same, removed top headset bearing and head as it was slightly notchy, now seems to be okay.
    Derailleur hanger screw not screwed in and no loctite applied.
    Shifters incredibly rattly, dealer said they were no worse than other bikes in their shop and there was no guarantee Shimano would warranty them. Others I have spoken to have said theirs make no noise. I will be sending them back soon.
    I have just ordered a new caliper and will fit that and hope the juddering is gone.
    Bar tape applied in 2 different ways and direction.
    Front derailleur not set up properly, stabilisation screw not used so was impossible to get correct shifting until I realised the shops mistake
    O rings that stop the axles falling out both ripped.
    All in, utterly shite!
    Definitely one for the not fit for purpose and reject under the Consumer Goods act, it sounds like a right bag o poop knocked out as a Friday afternon special a la british leyland et al!
    I’ve been so bloody lucky with bikes, even second user ones, my commuter/ute is 10 years old now and aside from a broken pin on one of the v brake arms it’s been ridiculously reliable and bombproof to boot despite been mashed, smashed and lots of urban miles.
    #951787
    extrusion
    rjfrussell wrote:
    How much of all that is down to cannondale, and how much just a shit build by your retailer?
    50/50 I guess, but the guy was asking about the topstone carbon and I detailed the issues I’ve had.
    Retailer is Tredz by the way, not the first time I’ve had issues with the pdi on a bike I’ve bought from them, but it is the last time I’ll buy a bike from them.
    #951785
    rjfrussell
    extrusion wrote:
    Yes, loads.
    Obvs experiences differ.  After 2 years of riding a 2016 synapse my LBS noticed a hairline crack on  a seatstay.  Took it back to Evans, they dealt with Cannondale-  frame replaced under warranty without question, and not only that, they allowed me to upgrade to the new model for only an extra £150 (whcih given they were both hi-mod frames was a huge bonus).  Fantastic response and service by cannondale and evans gatwick.
    #951783
    extrusion
    Yes, loads.
    Yes, loads.
    #951781
    Carax
    Yeh, I’m talking with the
    Yeh, I’m talking with the shop’s warranty debt now.
    It’s just so annoying.
    #951779
    pockstone
    When I say ‘get a new one’..
    When I say ‘get a new one’…I mean a new bike, not a new freehub with a nice long wait attached!
    #951777
    pockstone
    Sale of Goods Act..
    Sale of Goods Act…merchantable quality. ( I think those are the magic words.)
    Take it back to the shop… get a new one or satisfactorily repaired.
    30 days warranty on a freehub?…bollocks…see above.
    #951775
    Rapha Nadal
    Budgieman wrote:
    I have a Topstone 105 AL and have done 350 miles in 6 weeks without any issues.
    I’m looking at the Ultegra version via our C2W scheme.  What’s it like?  Looking to book in a test ride with Evans soon.
    #951773
    Drinfinity
    Ok, I stand corrected.
    I had a similar issue with daughter’s shock mount bolt working loose when new – blue loctite sorted that.
    I’d still be suspicious of the same happening at the hub axle though, especially when new and all the factory grease is nice and slippery. Obviously don’t want to use loctite there!
    #951771
    Carax
    Drinfinity wrote:
    By ‘Kingpin’ do you mean rear thru-axle? If so, you have to keep an eye on how tight it is, regardless of brand.
    If you were riding for any length of time with 3mm play at the chainstays, that won’t be good for the freehub. It is axle tension that is supposed to  cause the dropouts at the end of the chainstays to compress the freehub on to the wheel. Without that, a new hub could move sideways so the pawls are not engaging correctly (or splines if it’s a DT ratchet style).
    No, the “Kingpin” is the party piece on this bike. Allows the seatpost and seat stays extra flex, there’s sort of in built frame suspension
    #951769
    Carax
    Hammermason wrote:
    Hammermason wrote:
    Not a Topstone but a Synapse, freehub went after 3 months. According to Tredz C’dale view it as a wear and tear part, so only 30 days warranty! Maddux wheelset, same as the Topstone? Tredz were decent enough to replace foc.
    Ouch! Yes this is getting replaced, but it’s so frustrating as a new bike is out of action.
    #951767
    Drinfinity
    #951765
    Sriracha
    Hammermason wrote:
    That’s the stuff reputations are built of. C’dale – you just can’t pay for marketing like that – comes free of charge, but at great cost.
    #951763
    Hammermason
