Tacx Smart Trainer or similar
  • This topic has 5 replies, 3 voices, and was last updated 7 years ago by DoctorFish.
  • #30122
    DoctorFish
    Hi,
    I have recently torn the tendon from my pec to my arm.  I had an operation last week to reattach it but it is going to be some time before I will be able to ride a bike again.  Due to this I thought I would get a smart trainer so that I can cycle a bit indoors.  I’ve been reading a little about them over the last couple of days.  I prefer one that I can simply take the bike on and off, so this rules out the direct drive ones.  Also they are rather more exensive, and I hope it will not get so much use when I can get back out on the roads.  I like the idea of connecting up to Zwift or similar.  But certainly not for any kind of racing, just to make the training a little more interesting.  I basically want to do the equivalent of a leisure ride.
    I note that wiggle and others have the Tacx Bushido heavily discounted.  I presume this is because it is discontinued.  But the spec for it looks better that the newer replacements.  Any good reason not to just buy the Bushido?
    I have an Elemnt computer which will I assume play nicely with the Kickr Snap but that is quite a lot more expensive and I am reluctant to spend a lot.
    So thoughts on a discontinued Bushido, or a newer model of Tacx, or something else.
    Thank you.
  • #949969
    DoctorFish
    Gizzard wrote:
    I know I’m a bit late to this but I picked up the Bushido recently as an upgrade for my Tacx Flow Smart. It has its quirks but I’m very pleased with it as something for zwifting on.
    Thanks Gizzard, I ended up going for a Wahoo Snap in the end, pretty happy with it so far.
    #949967
    Gizzard
    #949965
    CXR94Di2
    Bkool pro is slightly more,
    Bkool pro is slightly more, fair device with automatic variable resistance wheel on turbo
    #949963
    DoctorFish
    CXR94Di2 wrote:
    [quote=CXR94Di2]Read the reviews-its ok, but be aware its very much budget Tacx Bushido Smart Trainer https://g.co/kgs/LCZDNP%5B/quote%5D
    Thanks, I appreciate it is very much budget, but I’m looking to keep a relative level of fitness going while I recouperate rather than training to be an athlete.  Is there something better for the money?  It is very heavily reduced, is a newer model at a similar price better?
    #949961
    CXR94Di2
    All wheel on turbos require accurate tyre pressure to give repeatable results. It all depends how long you’re going to be confined to indoor riding. I really enjoy indoor, probably more than outdoors
