Claris on-shifter cable adjuster?
  • This topic has 4 replies, 2 voices, and was last updated 7 years ago by ktache.
  • #30066
    kil0ran
    I’ve got some old Claris 8-speed shifters, the ones where the cable exits the side of the shifter rather than heading under the bar tape. I’ve never used them, they’ve been sat in the parts bin for a while. I was expecting there to be a barrel adjuster where the housing exits the shifter – should there be? And if so, any idea what the Shimano part number is? It doesn’t show up on the exploded views on the Shimano manuals website.
  • #949201
    8 speed works even when
    8 speed works even when covered in filth and with the chain in a terrible state.
    The cheap stuff is very cheap, but the good stuff is rare and shockingly pricey.
    Thank you for yor tale.
    #949199
    kil0ran
    All sorted, gotta love the
    All sorted, gotta love the huge tolerances of 8-speed. Wow the upshifts are loud, you could have headphones in and still hear them.
    #949197
    kil0ran
    Found the answer – no on
    Found the answer – no on shifter barrel adjuster, these are designed for a frame with downtube barrel adjusters. Outer just sits into the shifter body. Looks like I’ll need inline adjusters as my frame stops aren’t threaded.
    #949195
    kil0ran
    Update: looks like these are
    Update: looks like these are ST-2400 shifters, no thumb shift button.
    The equivalent part I’m talking about exists for Sora – https://www.sjscycles.co.uk/gear-spares/shimano-sora-st3500-cable-adjusting-bolt-unit-y6vx98050/ – anyone know if ST-2400 had the same system? The dealer manual mentions it but as it covers multiple shifters it’s not clear which instructions apply to which shifters.
