- This topic has 20 replies, 11 voices, and was last updated 15 years, 9 months ago by
Old Cranky.
October 31, 2010 at 9:16 pm #12832
gordonmarkus
Hi,
Just wandered if anyone else from Bristol had entered the Etape next year? I’ve signed up for the Alpine (Modane to Alpe D’Huez) stage, and if there’s anyone else who lives near me that’s doing it and might fancy getting some training in then let me know!
-Schleck Wannabe
Old Cranky
The Alpe is a brute and I was
The Alpe is a brute and I was grateful for my 28 sprocket on the Marmotte. I’d recommend fitting an 11-28 and at least you’ll have it in reserve.ironbloke
Happy New Year one and all.
Happy New Year one and all. Thanks for the comments – my interest is more about getting a feel for what might be required on the day, by simulating it in training; difficult I know. I just went for a bash up Burrington Combe with my new Allez set up (39/53 at the front and 13-26 at the back). Didn’t have to use the last 2 gears and tried to keep at 60+ rpm. On the flat the difference between the two chainrings will get some getting used to (my old bike had 52/42 with 11-24 at the back which was very smooth). Here’s to good training in 2012. 😀
dave atkinson
ironbloke wrote:Anyone know
ironbloke wrote:Anyone know of an application for hill climbing in France? A fellow cyclist suggested that there was an app which allows you to enter the hill in question, input your gear ratio / gear inches and it will tell you ther RPM required to climb it in a set time. Can’t find anything on the web and don’t know how to do the calculations. :/the calculation would, i think, go something like:
gear inches x 0.08 = metres of development, ie how far your bike travels per rotation of the pedals;
climb distance in metres / development = number of pedal rotations;
pedal rotations / time in minutes = RPM
so, if you want to climb the Soulor (13km) in an hour, and you have a 34/25 bottom gear (36″), the calculation is:
(13,000 / (36 x 0.08)) / 60 = 75rpm
I’m not sure how useful it is though, unless you’re just going to stick your bike in a particular gear and keep checking your cadence the whole time. It might work okay on a real steady one like the Soulor, it’ll be no use on the Marie Blanque or anything else with big changes of gradient…
macnmud
As someone who has ridden
As someone who has ridden many of the big climbs in the Alps and Pyrennees I wouldn’t worry about RPM. It’s simply a case of riding at whatever speed you can manage and arriving at the top whenever that may be.Nothing in the UK compares to these brutes and never underestimate just how low a gear you need. I would recommend 39 x 28.
Simon_MacMichael
Not as technical as what
Not as technical as what you’re looking for, ironbloke, but I’ve found the iCols app useful (well, from the safety of the armchair while watching eg TDF). Dozens if not hundreds of climbs across the Continent with gradients, route maps etc.Had a quick Google to see of I could find something closer to what you need but drawing a blank so far I’m afraid.
ironbloke
Anyone know of an application for hill climbing in France? A fellow cyclist suggested that there was an app which allows you to enter the hill in question, input your gear ratio / gear inches and it will tell you ther RPM required to climb it in a set time. Can’t find anything on the web and don’t know how to do the calculations. :/Garrigou
VC Walcot in Bath are a
VC Walcot in Bath are a pretty friendly bunch.
dave atkinson
ironbloke wrote:The other
ironbloke wrote:The other option might be to have a triple at the front? Any comments? I guess I would need to change the front shifter.a road triple will give you more or less the same range as a compact with a wide cassette, so horses for courses really. triple gives you closer ratios but it’s a bit heavier.
Fringe
ironbloke wrote:
I had a rideironbloke wrote:I had a ride with BADTri, who were great, but what cycle clubs are there in the Chew valley area? I’m at Bishop Sutton south of Bristol and 20 mins from Bath.
hmm, your in a bit of a nomans land there, obviously you got Bristol (Severn RC, Bristol South etc) and then in Clevedon there’s Clevedon and District RC, Bath..dunno.
could always start your own club (Chew Bishop RC?! 😀 )
ironbloke
The other option might be to have a triple at the front? Any comments? I guess I would need to change the front shifter.I had a ride with BADTri, who were great, but what cycle clubs are there in the Chew valley area? I’m at Bishop Sutton south of Bristol and 20 mins from Bath.
dave atkinson
SRAM Apex gives you a 34/32
SRAM Apex gives you a 34/32 which is 28″ or thereabouts; i’m currently testing it and it’s great to have a gear that low on a road bike. remember that if you do go above 28 at the back you’ll either need the apex rear mech or an MTB one for Shimano, as road ones aren’t designed for rear cogs the size of saucers 🙂ironbloke
I’m looking at gearing for
I’m looking at gearing for Act 1 (Modane to Alpe D’Huez) because my trusty (rusty) old steed has 42 at the front and 26 at the back which is about 40 gear inches. I think I need something more like a compact (39’ish) at the front and 34 at the back which I think would give me 27 gear inches and half a chance of only walking the realy steep bits!ironbloke
I have signed up and could do
I have signed up and could do with some training partners.etapechamp
have a good ride guys
have a good ride guysTwiggyHo
THANK YOU!
THANK YOU! -
