- This topic has 18 replies, 11 voices, and was last updated 7 years, 3 months ago by
Miller.
August 20, 2019 at 5:02 pm #30041
gonedownhill
Off to Saint Jean de Maurienne on Sunday for 5 days cycling up the Galibier and the like. Looking at the long range forecast (I know, almost certainly useless anywhere 5 days in advance, especially a mountain) just to get a picture of what to pack. However using a couple of different websites I am getting totally different answers depending on the website, even just looking at tomorrow’s forecast. Anyone got a go-to site?
Also recommendations of kit gladly received. Was kind of planning to go up in a short sleeve jersey with a packable rain jacket and maybe some long finger gloves for the descent but starting to think this may be underkill. Maybe have room for a ls baselayer to shove on to battle windchill on the way down but limited to jersey pockets and those will need to have a couple of thousand callories of food in.
Thanks.
Miller
Take care on the descents.
Take care on the descents. Some in my club have got over-excited on encountering real mountain descents and have posted the results from their hospital bed.
Back to back big mountain days are very draining so perhaps schedule some lower altitude riding.
By late afternoon you’re going to want to be showered and installed in a bar.
Moist von Lipwig
gonedownhill wrote:
gonedownhill wrote:If anyone wants to chime in on their favourite climbs while they’re here then go ahead. Current thinking is Telegraphe-Galibier one day, then also try and do north side of Glandon, Croix de Fer from the south side (approaching from Bourg D’Oisans), Alpe D’Huez, Lacets de Montvernier & Col du Chaussy over the course of the week.
Did telegraph/galibier and Croix De Fer in one go, that was the best and hardest day I’ve had on a bike. Croix was a slog on the limit by that point. Probably a much nicer couple of hours when you’re not breathing through your arse.
Lacets is great, one of my favourite bits of the week, Chaussy isn’t too demanding, if feeling okay in down the other side and you’re part way up the Madeleine.
Glandon from St. Jean let’s you then do La Trousierre or the Mollard.
Griff500
jaysa wrote:
jaysa wrote:“And you think you can do the Marmotte (175km, 5000m climb) on 2000? Dream on”
Settle down
For sure the Marmotte burns more than 2000 Cal.My point was 2000 Cal is a lot to take with you when every cafe/resto/bar is open.
Sorry, I clearly picked up your post wrong!gonedownhill
Mountain forecast is the one,
Mountain forecast is the one, thanks.
Think I may have been underestimating how much opportunity there is to buy food up at altitude – the presence of a brewery is a monumental bonus!
Cheers all for the helpful comments.
All very dependent on how we handle back to back Alps days as both me and my riding buddy are a bit less trained than we’d hoped having both had football injuries at the start of the summer. We have a car so have options to drive to reduce overall kms and time and get to near the start of the climbs.
HLaB
When I did the Marmotte one
When I did the Marmotte one of my mates suggested a light wind proof jacket for the highest point and descent from it which was a good call. Took the jacket off in the feed stop down the bottom. The rest of my gear was summer stuff.
jaysa
Settle down
Agree on the total energy burnt – though if you’ve trained your fat metabolism, a fair amount comes from fat reserves.
I’m based in the Hautes Alpes and on long days have burnt lots of Cals – I try not to carry umpteen energy bars though!
e.g. rode Allos, Cayolle and Bonette in the day, carrying max 4 bars + meals in the valleys, and restocking with more bars from the car before the Bonette.
PRSboy
But all that said about
But all that said about calories, I personally never find I get madly hungry even on some big days… aim to eat well rather than like a sumo wrestler.
The worst I felt on a climb was the Madeleine on a hot afternoon, after a freezing wet and windy morning on the Col Du Glandon after which I thought I deserved a big pizza for lunch
Griff500
jaysa wrote:2,000 Cals is a lot – even for the Marmotte circuit?
Nonsense!
A “typical” figure for leisure cycling is 500-700 cals/hr, and that is before factoring in an 8% climb.
Another figure often quoted is that a “typical” 75kg cyclist at 18mph uses 900 cals/hr. Again, Galibier is not typical.
Livestrong give an example of an 80kg cyclist at 10mph on only a 3% incline burning 850cal per hour.
These figures, all from different sources, seem fairly consistent, but the burn rate increases dramatically with gradient. (even accounting for the fact that half of a col attempt is downhill).
My cycling all takes place in mountainous terrain. Galibier from Valloire return took me 1500 calories (36km round trip with 1200m climb). The Cinglés (138km, 4405m climb) was 5671 calories. According to my Wahoo, yesterday’s little jaunt round the Vaucluse was 90km, 1287m climbing, 3h30 moving time, just short of 3000 calories. Again, this all ties in pretty well with all the numbers I can find online. And you think you can do the Marmotte (175km, 5000m climb) on 2000? Dream on.
So I reckon if you are off for a few days cycling cols, 3000 per day should be the minimum you expect, and Marmotte, much more.
I strongly recommend the Galibier brewery in Valloire as a useful source of calories!
Griff500
Avoid the “tourist” type
Avoid the “tourist” type forecasts such as AccuWeather and meteo.fr as they don’t accurately detail altitude, and their forecasts are usually extrapolated from somewhere else. Use mountain-forecast.com, select the nearest relevant mountain from their database (eg pointe des cerces for galibier) and you will get an hourly forecast with temperature versus altitude, plus freezing level.In August the weather can be almost anything in the Alps so pack as such, and decide on the day what to take. Typically early mornings can be cold, but the sun is still quite high so it can be very hot by 11am, and very often thunderstorms late afternoon.
I did Galibier in early July, and you’ll love it. The scenery is just so spectacular.
LastBoyScout
I’ve never bothered taking a
I’ve never bothered taking a rain jacket cycling in the summer – you just end up soaked from sweat, anyway.
I’d wear a mesh base layer and jersey and take a windproof gilet and a set of arm warmers. As Shades said, it can be significantly cooler at the top, especially if you’re soaked in sweat.
Agree with the lights idea due to the tunnels.
jaysa
Good point on the lights –
Good point on the lights – sorry forgot that.
Also take and use a rear flashy light. People drive through tunnels with sunglasses on and may not see you without one. Keep well away from the wall in tunnels – there can be a deep gutter and rocks rather close to head level.
You can often watch storms brewing – more and darker clouds. Just set off early to avoid and get a cool(er) ascent.
gonedownhill
Thanks for the replies, most
Thanks for the replies, most useful. Windy.com is a great resource.
Will take a bunch of rain kit to France with me but looks like packable rain jacket, cap, maybe a buff should cover a typical day especially if storms are mostly late afternoon by which time we should have completed most of the rides we have planned.
Google translate downloaded.
Can’t find the water point app but this website is pretty good https://www.eau-cyclisme.com/eau-departement-savoie-d73.htm
Was going to take lights anyway but good tip.
Shades
Even in July I’ve been
Even in July I’ve been sweating buckets in the valley and then sitting in a cafe at the summit; jacket and hat on with a mug of hot coffee.
PRSboy
+1 on the lights… there are
+1 on the lights… there are a few tunnels that you may have to negotiate. Not all are lit inside. One long one I recall on a main road had a lighting failure and would have been the end of the ride without lights.
Otherwise, prepare for all weathers as Alpine weather is very changeable even if you’ve seen a forecast. Keep a gilet with you for the descents, and a rain jacket.
Enjoy… my week in the Alps was the best time I’ve had on a bike, ever. Make sure you look up from the stem at the amazing views!
Liam Cahill
The essential is a packable
The essential is a packable rain jacket. A cotton cap is also very useful. You can be all chic at the cafe and it’s great for avoiding brain freeze when your sweaty head starts the 30min descent!
Oh – lights. Overkill for most of the day, but the extra weight is worth it if you have a mechanical that means you’re getting back late. And some of the thunderstorms over there make it amazingly dark…
