- This topic has 18 replies, 10 voices, and was last updated 6 years, 11 months ago by
SamShaw.
August 2, 2019 at 10:02 am #29977
SamShaw
I’ve just (today!) gone tubeless on my road bike with 25mm Schwalbe Pro One tyres. They’re on, holidng pressure, no problems so far.
Part of my reasoning to go tubeless was to cut down on the amount of ‘stuff’ in my jersey pockets when out riding. Having done a bit of research, the recommendation seems to be to carry a plug repair kit (the worms / anchovies) and a mini-pump rather than the usual CO2. CO2 supposedly not as good for re-inflation if you need to plug a hole and get the tyre back up to pressure.
Questions:
1. Do those riding tubeless agree with the CO2 issues mentioned above.
2. Anyone got small mini pump recommendations (to go in a jersey pocket). -
SamShaw
Having got a Road Drive on my
Having got a Road Drive on my gravel bike, I went with a HP Drive Small. Not had to use it yet but seems the usual Lezyne quality. https://ride.lezyne.com/products/1-mp-hpdr-v2m04
Carrying this with a small kit of anchovies and the tools to insert them. Suppose the big test will come when I actually get a puncture.
I use Specialized airtool MTB
I use Specialized airtool MTB pump, not the mini. Has an easy frame fit mechanism or you can put it in your jersey pocket. It’s the best pump I’ve had (that relaistically fits in a pocket) and bought a second one which was the newer version in black that is shorter but slightly wider/bigger capacity.
Dicklexic
4+ years riding tubelss and I
4+ years riding tubelss and I STILL carry a spare tube with me just in case, alhtough I’ve only ever needed it when a ride buddy used up both his spares on one ride and then got a third punture. Then I’ve also got a cheap ‘anchovy’ type repair kit in my saddle pack and a Lezyne Pressure Drive pump (with the hose) fixed behind the bottle cage on the seat tube so it’s nicely tucked out of the way.
SamShaw
dooderooni wrote:
[quote=dooderooni]I don’t run tubeless, but I do use the Topeak Race Rocket which fits the bill for portability, valve attachment and also comes with a valve core remover.https://www.topeak.com/global/en/products/mini-pumps/333-racerocket%5B/quote%5D
That’s made it on the shortlist – cheers.
SamShaw
peted76 wrote:
peted76 wrote:I have two ‘carry along’ set ups ref tubeless.
1) Normal local’ish distance stuff = 1x CO2 & inflator head, 1x Small bottle with about 20ml sealant in, 1x Value core remover.
Cheers, that’s really helpful. Also been recommended to take a bottle of sealant.
2) Longer more self-sustained stuff = as above but, I’ll swap out the CO2 for a small pump and include 1x Set of tyre Worms.
One day I’ll get a dynaracer kit.. but for now the genuine innovations cheaper set of worms will do.
dooderooni
peted76
SamShaw
hawkinspeter wrote:It might seem a bit of a rip-off when you can get an Innovations kit for a fiver: https://www.amazon.co.uk/Genuine-Innovations-Unisexs-Tubeless-Multi-Coloured/dp/B00B139BA0
Yeah, but it looks a fantastic well thought out wee package.
SamShaw wrote:
SamShaw wrote:
TBH, it was the kind of thing I was thinking of – but… 35 quid?!hawkinspeter wrote:hirsute wrote:
Now that is a beautiful piece of kit. I am conflicted with hoping not to have to use it with wanting to use it.hawkinspeter wrote:If you’re in the mood to “waste” lots of money, then I can recommend the Dynaplug Racer tubeless kit – works really well and is in a conveniently small package: https://www.amazon.co.uk/dp/B07MH9K4NRI also have a topeak mini morph g which is a little too big for a jersey, but you could attached it to the frame. It does inflate well.
I’ve only had to use the Dynaplug Racer kit once and it worked very pleasantly. Unscrew it, ram it into the tyre (preferably where the existing hole is) and pull it out with the anchovy staying in place. A quick blast of CO₂ and I was cycling again with the whole job taking less than two minutes.
SamShaw
SamShaw
Joe Totale wrote:
Joe Totale wrote:I carry CO2 with me just in case the tyre unseats itself as a hand pump will never reseat it.
I also take a hand pump to reinflate the tyre as CO2 can force the sealant out of the hole that it’s just plugged up. I use this tiny little thing which does work well despite it’s size:
https://www.giant-bicycles.com/gb/giant-control-mini-pro-pocket
I’ve given up taking a tube with me now as I’ve been able to carry out repairs with tyre worms which took far less time than changing a tube. This means I don’t need a saddle bag and carry less than when I used tubes, I must say this has been quite liberating.
I’d looked at a fixed-head micro pump, but thought that one with a hose would be preferable.
SamShaw
HLaB wrote:
HLaB wrote:The one blow out I’ve had to fix with a worm so far I used my Leyzne Pressure Drive it seemed to work fine and I carry it in my pocket.
I’m looking at the HP Drive Small right now.
HLaB
