Basic bike maintenance
  • This topic has 7 replies, 8 voices, and was last updated 7 years ago by kil0ran.
  • #29887
    stevedee
    I’m relatively new to cycling, at least in terms of doing it regularly. I find myself now without a car until mid-October….so have bought a new bike (Cannondale Topstone gravel bike) and intend to use that for the bulk of my commuting – at least 3 times a week, circa 20 miles a day. I’m using a route which is a combination of road and trail/towpath, so there will undoubtedly be muddy days in there somewhere 🙂
    I think I can say that my history of bike maintenance is low…..like I don’t think I have ever cleaned or done anything to a bike beyond adjusting my seat post and maybe once I repaired a puncture…..
    I don’t want the new bike to go the way of past bikes, and want my commutes to be as comfortable as possible, so looking after the bike is important this time. I am a bit clueless on what a basic level of bike maintenance looks like. How should I, and how often should I clean it? What is classified as cleaning it, full on pressure wash, wipe down? Daily, weekly? Do I clean the chain, how? Do I need lube, which one? Do I degrease it, how?
    So far, this week I had a couple of dry days and one wet day. On the wet day I just wiped the bike down with an old towel at the end of the day when I got him and that was it..
    Any advice, help much appreciated
    Thanks
  • #945975
    kil0ran
    Depends whether you’re time
    Depends whether you’re time-rich or not. If you don’t clean your drivetrain regularly it will wear out and need replacing more quickly than if you do.
    Replacement cassettes and chains are easy to fit and will take a lot of abuse, particularly if you run a heavy wet lube in the winter months. You’re looking at £50 and an hour to fit for a replacement cassette/chain versus say 30 minutes a week to keep everything spick and span.
    Keep an eye on the pad wear as that’s critical to safety – and consider swapping pad compounds if it gets really wet before you’re back in your car.
    You’ll probably find that your shifting will go out of whack in a few weeks as the cable outers bed down into the ferrules. Manifests as a slow shift and usually fixed by a quick (and small) tweak of the barrel adjusters. Do it in half-turn increments and test under load (with you riding, rather than on a workstand)
    Mudguards if you can fit them go a long way to keeping you and your bike as free from grime as possible.
    #945973
    Boatsie
    Ditto chain.
    Ditto chain.
    Lubes such as pictured are awesome. Different colours to suit conditions. Eg. Dry, wet, a bit of both.. Whatever suits you.
    LBS here has RockNRoll and Muk Off. I’m sure there’s probably others.
    Basically clean chain, cogs, cassette. Apply lube, wipe off excess (the lube’s designed to penetrate near fulcrums of chain).
    The screws on the back of the derraileur are the outer and inner limits of the cassette. When shifter doesn’t shift properly (the step adjustment), that’s the connector at the end of the cable. The screws let the chain know the boundaries, the cable itself has a tension adjuster that allows the control of shifts. The tension is usually the adjustment bit.
    Lubes like those are awesome
    #945971
    CXR94Di2
    Steering, stopping,
    Steering, stopping, propulsion.
    So pay attention to handlebars for smooth non grinding motion.
    Check brakes over once a week for wear or unusual noises.
    keep chain and gearing clean and lubricated, especially on wet muddy days.
    Get a set of mudguards, it will keep you and the bike much cleaner.
    also get yourself some decent lights, may two sets.  I like NiteRider 850 front and they do a nice bright rear light too.  They are rechargeable, so have a charger available at work and home.
    #945969
    RMurphy195
    The chain, as others have
    The chain, as others have said.
    If you have clipless pedals, keep them free of mud and crud (and the cleats as well, of course!)
    Keep an eye on the brake linings. If you have rim brkes,clean mud and grit of the rims and the brake pads.
    #945967
    Spangly Shiny
    Try these vids from GCN they
    Try these vids from GCN they are generally a pretty good start point for learning how to do most things about looking after your bike.
    #945965
    Ditto about the drivetrain.
    Ditto about the drivetrain. You can never spend too much time caring for your drivetrain.
    Check your tyres have sufficient pressure every so often as well as that can make a big difference to how fast the bike goes and may provide warning of a slow puncture.
    If you’re going to use a pressure washer, try to avoid shooting water at any of the bearings as the pressure can allow water to get past the bearing seals and then cause corrosion. Personally, I use a bucket with warm water and car shampoo (doesn’t have salt in like washing up liquid) and some old washing up sponges when my bike has some dirt on it (probably every other week).
    In general, bikes don’t require much maintenance, but pay attention if a new noise develops whilst riding. Although noises are notoriously difficult to pin down, they often signal that something has worked loose or needs attention.
    #945963
    The most important thing is
    The most important thing is to keep the drivetrain clean.  The rest doesn’t really matter, that’s just aesthetics.  But the chain, a very good wipe down (at the very least) and lube once a week might do you, but depending on the filth maybe more.  If  it’s especially grimey, a chain cleaning device once or twice a month, and a strip down every couple of months.  You will then start needing tools.
    Enjoy the obsession.
