Converting Formula RX-512 hubs from thru axle to quick release
  • This topic has 3 replies, 3 voices, and was last updated 7 years ago by lawrencesly.
  • #29875
    Zermattjohn
    I’m switching the front wheel that came on my caadx to my other bike. The caadx wheel is a thru axle, Formula RX-512 12×100. Anyone got any knowledge of whether a conversion to quick release is possible? Thanks.
  • #945797
    lawrencesly
    Zermattjohn wrote:
    Ace, thanks. Seems a fair bit of cash for what is basically a plastic collar..! I’m doing this because the stock wheels on the CAADX are heavy, clunky trash and I’m pretty sure my tubeless-setup Hunt gravel wheels  will improve the situ significantly..
    Hi Zermattjohn,
    Did this solution work for you? I am in the same position so wondering what to do as I’m not sure how to find the correct replacement end caps.
    Thanks
    Lawrence
    #945795
    Zermattjohn
    #945793
    Drinfinity
    What you would like to get
    What you would like to get are replacement end caps, although I don’t know exactly what would fit there – notoriously difficult to get spares for apparently. Maybe some generic ones would fit?
    If you can’t find the end caps, you can just put in an adapter axle.
    https://www.halowheels.com/shop/spares/hub-spares/12mm-to-qr-thru-axle-adaptor/
    Cheaper ones can be found on your favourite interweb sites
