- This topic has 5 replies, 3 voices, and was last updated 7 years, 5 months ago by .
I bought an Avanti Blade 3*9 speed. Lovely bike. Frame triangles suit me.
Anyway.. Wanted a fixie to learn technique.
Bought another Avanti Blade. Avanti Blade8. Same triangles, rear axle with a horizontal feed instead of a vertical feed. Didn’t realize about axle widths, chain.. Kept as is.
Now riding two near same frames..
The derailer feels faster when serviced. I prefer that bike during dry rides. It’s less effort to maintain a same speed. However. The cog ratios are different. A preferred route of mine is a constant shallow down gradient of 20+km and that girl top cogs via 52-11
However, the hub gear bike doesn’t need cleaning after stormy rides, it just stays serviced. Today I noticed a creak sound. Having been ridden all year, all weather, I know that my laziness of chain lube (currently middle of year, last lube was last year) could be rectified tomorrow and fixed within 5 minutes. Clear, clean, wax, done.
So although slightly slower when both are serviced, because it basically services itself it remains a consistent reliable machine in terms of known road speeds per effort upon pedals applied. Cogs don’t wear much neither, comparable to a single speed. Internals? I ain’t worried.. If she ever blows it’s simpler than a derailer. Flip it out and plug a new one in.Pros of hub gear… Simple. Single chain length. Ideal if Bafang crank or similar electric machine assistance was to be applied. Weather proof. Reliable. Doesn’t require maintenance (very minimal) . As easy as a BMX.
Pros of derailer. Weight distribution. Performance gains. Familiarity regarding many peoples uses of. Rear tyre changing if ever needed.
Hub gears make a good work horse.. Shopping, Heavy work tools, etc.
Race bikes have derailers hence they are faster but require maintenance. Both above are pretty minimal.
