Any Argon 18 owners?
  • #29766
    IanS82
    Good Morning all,
    I’m currently looking at an Argon 18 Krypton, but am confused with the sizing; I currently ride a size 54 Cannondale SuperSix Evo, I am 5’10’ with an inside leg of 31 inches. Looking at the Krypton sizing and geometry, a small seems to be the closest fit. I’m not in a position to try to the bike out before ordering.
    Could any Argon 18 confirm if this sounds about right, and the frames come up larger than normal?
    Thank you,
    Ian.
  • #944091
    gbzpto
    I am usually an M but when
    I am usually an M but when trying one had to down size to an S. Had to put a 70mm stem on as well .I wanted to like it but Ended up not buying one. It just felt too stretched.
    #944089
    PRSboy
    AfterPeak wrote:
    AfterPeak wrote:
    PRSboy wrote:
    I am 5′ 9 and have a medium frame Argon 18 Nitrogen, which fits me very nicely.
    A beautiful bike.
    It is one of the better looking aero bikes IMHO, and feels great to ride.  Fast but surprisingly comfortable, handles beautifully through bends.
    Looks after me too – only this morning I had a big moment at over 20mph when I swerved hard to avoid a big branch sticking out of the hedge, hidden in the shadows.  Hit a pedal on the floor, thought I was going down but miraculously it straightened up with no drama and I was on my way.
    All in all, highly recommended, but they seem to fly under the radar in the cycling press.
    #944087
    AfterPeak
    PRSboy wrote:
    A beautiful bike.
    #944085
    PRSboy
    #944083
    IanS82
    Thank you both, appreciate
    Thank you both, appreciate your help.
    Ian.
    #944081
    AfterPeak
    I am the same height as you
    I am the same height as you and when I tried one in the shop they sized me a medium frame. I didn’t buy it in the end but hope that helps
    #944079
    CXR94Di2
    IanS82 wrote:
    Apologies, it’s a 2017 SuperSix Evo.
     The Krypton would be a 2018 model.
    Thank you for your reply and help, it’s appreciated.
    The Canondale over the years has changed very little apart from a few millimetres here and there.
    I still think its 54-56 Argon is the correct frame bike to compare.
    I always check reach, stack, head tube length to compare for bike fit.  Head angle and overall wheelbase determine handling characteristics.
    #944077
    IanS82
    #944075
    CXR94Di2
    Looking at the tech specs you
    Looking at the tech specs you would need a ‘Medium’ 54-56 to nearly match frame dimensions of the 54cm Cannondale- You didnt say which year is your super six?
    https://geometrygeeks.bike/bike/argon-18-krypton-2018/
    https://www.argon18bike.com/uploads/files/techcards-a18-2016-eng-krypton.pdf
    https://geometrygeeks.bike/bike/cannondale-supersix-evo-2013-2015/
    There is about 7mm between ‘reach’ the Argon being longer (shorter stem would correct)
    ‘Stack’ virtually identical
    head angle 0.2 deg difference.
    54-56 Argon is your size, if your current bike is a good fit
