- This topic has 19 replies, 7 voices, and was last updated 7 years, 9 months ago by
maviczap.
January 26, 2019 at 6:13 pm #29316
Huckfinn
Having found the (“pre-loved”) bike I’d been looking for for a while:
https://www.giant-bicycles.com/gb/2014-giant-tcx-advanced-1-2014, as per title I’d like to slightly tweek it for use in the steep hills of South-East France.
Basically: with a setup that has a Cassette SRAM 1050 11-28 coupled with a Crankset Rotor 3DF 36/46 what are my oprions? I’d like to get just below the 1 to 1 ratio for climbing as opposed to the current 36:28=1.28.
Any coment would be appreciated!
Huck.
maviczap
CXR94Di2 wrote:The issue you have with the Rotor crankset is it has 110mm BCD.Generally that restricts the inner ring to 34t. Absolute Black do smaller rings, but I cannot find if these rings fit the Rotor crank-hence email enquiry.
The road link is a cheap way to fit a larger cassette whether 11-36 or 12-36. You might need a slightly longer chain, but fitting cass will make it clear.
I would approach these steps in this order
Fit 12-36 cass and road link, check and adjust rear derailleur if needed and check all gears are possible.
Once satisfied look into modify crankset.
Email Absolute Black in the meantime for information.
For a 5 arm 110bcd crank you can get a 33t Stronglight chainring which I have on an ultegra 6750 crankset. No one does any smaller chainrings singulaly
Or Praxis works do a 48/32 five arm 110bcd chainring set. You have to have the pair as the 32 ring attaches to the 48t outer, it’s clever engineering to allow the use of the 32 on 110bcd.
Cheaper than Absolute Black, which I’ve just bought for my 4 arm Dura Ace chainset in 46/30 format, but the chainrings are lovely
Spangly Shiny
WiFli rear mech works fine
WiFli rear mech works fine with a 11/34 cassette, have not tried it with 11/36.
Huckfinn
You are a proponent of the
You are a proponent of the “one step at the time” approach
…wise
thanks for that !
CXR94Di2
Its not too weird, but I
Its not too weird, but I would hold off and just get the 12-36 cassette
If in the future you want even lower, look at the FSA Adventure crankset. That has a 90mm BCD and will take 30t inner chainring
Huckfinn
I will
I will
Thanks!
In the meantime here’s response from Rotor:
“..that crank should have a fairly standard BCD… If you are currently running a 36t ring it likely means you have a 110×5 bcd spider on that ring and you can easily put any of our 110×5 bolt chainrings on that spider. We offer down to a 34t chainring that will fit a 110bcd. A 32t ring will not fit on a 110bcd as it is a smaller diameter than the bolts would be” (….as you suggested)
Also: “Yes, you will have no problem replacing the cassette with the 1070.”
Cool! Now I’ll check with AbsoluteBlack
Concerning the link I posted :https://www.wolftoothcomponents.com/products/giant-cog-for-shimano?variant=629914645
is it just too weird..?
CXR94Di2
Huckfinn
Ok
Ok
Let’s forget about that (but, WAIT, what about this?: https://www.wolftoothcomponents.com/products/giant-cog-for-shimano?variant=629914645..)
So the bottom line is
1- Replace the 36t in the Crankset with a 34t
2- Replace the cassette with Powerglide 12/36
3- Install Roadlink and check chain compatibility
…..That’s all, right?
AND/OR: Can I go smaller than 34t in the Crankset?
CXR94Di2
Not in 10 speed. If you
Not in 10 speed. If you wanted more, it then involves new 11 speed shifters derailleur and cassette.
Huckfinn
Thanks for the suggestion!
I’ll check with Sram about compatibility.
That would be the Powerglide PG-1070 right? (55Euros is perfectly fine)
Can you get any higher than 36..?
Fish_n_Chips
Check the rear mech gear
Check the rear mech gear range.
Change the inner ring.
Check chain tension/length/adjust.
Build legs up by intervals up a hill.
Recover and eat well.
CXR94Di2
Huckfinn wrote:“Youve bought bike, modify away”
At the beginning you said:”…swap the inner chainring to 34t. Swap the cass PG1030 11-36 10 speed.”
That’d be just fine! ok, if 34 inner chainring is sufficient.
What is the roadlink for (& would I need it even if I kept the existing 36tchainring)? The Road Link is a small bracket which lowers the derailleur- allowing bigger cassette to be fitted eg 11-36
Do you think I’d have to also swap the shifters or whatever the mechanism is called? No the shifters stay the same because you are staying with 10 speed. The bike is currently 10 speed
See my comments
alansmurphy
Just as a word of advice, if
Just as a word of advice, if you’re going for more climbing gears you really need to look at your gears past the midway point. I added a 34 or 36t rear cog onto an 8 speed when recovering from injury so had a 34t front and 11/34or36 rear, it was horrible.
The jumps between cogs made the next gear up from the easiest ffel like you were climbing in the worlds toughest gear. You either need a 10/11 speed cassette or be prepared to drop the 11t 13t etc. cogs!
Huckfinn
CXR94Di2
You would need to email
You would need to email Absolute Black to confirm which of their sub compact chainring fits the Rotor crank . If they dont fit and you still want 30-36 combination, it will involve crankset change(possible bottom bracket bearings) too.
As per previous thread, its a case of buying a bike and modifications or frameset- build your own. Youve bought bike, modify away
Huckfinn
Hi,
Hi,
thanks for that! (by the way, In The Court Of The Crimson King, , brings back nice memories!!).
Anyway, I notice on their page that the WiFli only supports up to 32t. Is that correct?
PS: what about something like the AbsoluteBlack 46/30 sub-compact chainrings. I could replace the current chainrings with that (or maybe just the 36t with any 30t one)?
AND replace as suggested the cassette with a PG1030 11-36?
30 chainring with 36 at back seems excellent for climbing!!
