- This topic has 7 replies, 4 voices, and was last updated 8 years ago by .
After 10 years I pensioned off my Tiagra 4500 triple groupset on my winter bike (Titanium with external routing). I got some used shifters and bought everything else new, mechs, chain, cassette (all 105 5700), bottom bracket, and cable inners and outers. My LBS sold me 1.1mm gear wire (Sram I think) along with standard outer. Having put it all together I find the shifters require more of a push to shift to a larger sprocket or chain ring than on my summer bike (carbon with internal routing) which has exactly the same set up. The gear cables are routed round the outer radius of the bars, and I used ferrules from my LBS. Changing the other way is not a problem. Another shop has suggested changing to a standard Shimano road gear cable set, but I see sets on line with Optislick coated gear wires, sold as designed for 105 5800. Looking at the packaging I think the ferrules are different. Are the ferrules only compatible with 5800 mechs and shifters? Can use the Optislick set on my winter bike? Will I get noticably better shifting with it compared to a standard shimano set? I have got a new bottom bracket cable guide and bar tape and want to change the cables only once. I have even bought new cable guides for in the shifter hoods so as to leave no stone unturned. Any help would be greatly appreciated.
