- This topic has 8 replies, 6 voices, and was last updated 7 years, 11 months ago by .
I bought a handbuilt wheelset from Spa Cycles in January 2017 (Tiagra 36h hubs, Rigida Sputnik rims).
3,300 miles later (November 2017), the rear hub flanged snapped – around a centimetre of the circumference of the flange broke off on the non-drive side, meaning that two spoke holes also disappeared.
The rear wheel was sent back to Spa Cycles who replaced the hub (with exceptional service) under warranty.
4,000 miles later (this week), my rear wheel came out of true and, upon inspection at my LBS, the new hub has 5 visible cracks running from individual spoke holes to the edge of the hub. Two of those cracks are sufficiently large that there is a visible gap in the metal between the spoke hole and the edge of the flange – i.e. I can see through it.
My understanding is that hub failures are rare. Does this simply sound like (very) bad luck? Or could there be something else about the wheel which is causing this to happen?
This is on my commuter bike. The stock wheels lasted 10,000 miles before I replaced them (worn rim; hub was still running fine).
