Snapped Mudguard Screw – Any Remedies/Hacks?
  • This topic has 7 replies, 6 voices, and was last updated 8 years ago by StraelGuy.
  • #29079
    road
    Following an impact from a car where my mudguard “concertina-ed” in on itself I’ve been performing ongoing repairs to my Orro Terra Gravel.
    Today I set about un-screwing my mudguard struts when one of the screws sheared, leaving the shaft stuck within the eyelet – completely flush to the frame surface. I’m somewhat gutted as I’m sure that i applied grease to the thread prior to installation last September (2017).
    I’m just wandering of you esteemed, knowledgeable people have an ideas for the removal of said screw. Is it best to just drill it out and re-thread it with a tap & die set or is it best to use one of those bolt removal kits?
    Any advice would be greatly appreciated?
  • #930243
    StraelGuy
    Any news Rose?
    Any news Rose?
    #930241
    Mybike
    yes if it a though hole try a
    yes if it a though hole try a vice grip on the other side usually there a couple of mm you can grap on
    #930239
    Wow, thanks for your timely
    Wow, thanks for your timely responses, guys. That’s my weekend sorted.
    Hoping to retain the frameset’s all weather capabilities. She’s been through alot. Three impacts from motor vehicles and still running straight and true. I’m thinking of naming her Lady Luck.
    #930237
    You can buy a set of reverse
    You can buy a set of reverse screwdrivers from your local DIY store B&Q do a set for £7 I think. Drill a small hole to get the bit started, should come out easily enough as you’ve greased it.
    If it doesn’t come out you could drill it so that you are left with a very thin amount of metal left without damaging the threads which should be easy to unthread the rest.
    GL
    #930235
    ChasP
    No need for a reverse drill
    No need for a reverse drill as it’s a through hole, if it grabs it will screw out the other side.
    #930233
    Canyon48
    Be really careful, you don’t
    Be really careful, you don’t want to damage the threads.
    As strael says, a reverse 3mm should do it.
    The other possibility is getting a 2/2.5mm drill in the tread then tapping in a 3mm torx key and trying to get it out that way.
    #930231
    StraelGuy
    Your best bet might be to
    Your best bet might be to order a 3mm reverse twist drill. When you try and drill it out, it will probably grab the threaded shaft and spin it out of the frame, it’s good that the thread was greased as this will increase your chances of success considerably.
