Winter softshell jacket recommendations
  • #29067
    Russell Orgazoid
    I’m looking for the above that will ideally be like a Gabba/Perfetto type but more suitable for temperatures below 10deg C down to low single figures.
    Not fussed on brand. Slim build, 69kgs and 5ft8. I’m a bit of a sweater so it doesn’t need to be super warm.
    Many thanks in advance!
Viewing 15 replies - 1 through 15 (of 15 total)
  • #929845
    TheScotsman
    Bought a Perfetto convertible
    Bought a Perfetto convertible in a sale towards the start of the year.
    I was sweaty and roasting in it (wearing a dirt-cheap Planet X long-sleeved baselayer underneath) on my 9.5 mile ride to work last week when temps started at 7C and were down at -0.3C by the time I got near work.
    I do naturally run hot, but I didn’t feel the cold at all even before I’d started pedalling (and in lesser items I usually do).
    I also own & can recommend a convertible Gore Phantom 2.0 windstopper softshell (bought 2014) that’s excellent and warm with or without a base layer.
    #929843
    iandusud
    Another vote for the Galibier
    Another vote for the Galibier Mistral. https://galibier.cc/product/mistral-foul-iv-weather-jacket/
    Read the reviews and believe every word. Best bit of cycling kit I’ve ever bought.
    #929841
    Richbeck
    7mesh Corsa or Parentini
    7mesh Corsa or Parentini Mossa – be different! Etxeondo Summum when it’s proper brass monkeys!
    #929839
    Nat Jas Moe
    I have a RH+ alpha padded
    I have a RH+ alpha padded jacket, its good down to -5 to +12. Keeps me warm and toasty
    #929837
    ClubSmed
    https://road.cc/content
    https://road.cc/content/review/218748-planet-x-365-magma-convertible-jacket
    I wear the PlanetX Magma when it starts to get cold. The body in a nice snug fit and the arms are a little loose so you can also wear arm warmers underneath if needed.
    #929835
    srchar
    Plasterer’s Radio wrote:
    Does anyone have a Castelli Alpha ros?
    is it too warm? thats my fear. I’d like something more than Gabba in terms of warmth…but maybe just a wool base layer will do.
    Again, thanks for any opinion.
    I have an Alpha ROS and a Perfetto.  I run hot.  It’s only just got cold enough (at 5C) for the Alpha.  Anything warmer and I reach for the Perfetto.
    I think you’re right to consider a light jacket and base layer.  In autumn, when the commute is cold in, warm out, I’ve used Perfetto + Prosecco base layer in the morning, then ditched the base layer for the ride home.  That combination effectively gives you an Alpha in terms of warmth, athough the Alpha would be better in the wet.
    Alpha ROS and Perfetto both available around the £100 mark if you shop around and both well worth it at that price.
    #929833
    jacknorell
    If you run warmish the Alpha
    If you run warmish the Alpha jersey should work well.
    #929831
    Stratman
    I’ve got the Alpha jersey, which has unlined arms and a fleecy back, and the Alpha Jacket which has lined arms as noted above and is all soft shell.  I was in the jersey today with a short sleeve merino base layer.  Just below freezing at one point, but mainly low single figures and I was warm enough once I’d got moving.  I would probably have been alright in the jacket too,  but might have overheated on the way home. A Perfetto and long sleeve baabaa is also good down to a little below freezing.
    #929829
    Mathemagician
    Galibier’s Mistral and/or
    Galibier’s Mistral and/or Mistral Pro are both great. I say and/or as you could pick up both for the price of some of the other stuff being mentioned here.
    #929827
    Russell Orgazoid
    #929825
    MoutonDeMontagne
    Depending on baselayers, I
    Depending on baselayers, I wear a LS Gabba/now perfetto down to about 5 degrees and am just about warm enough.
    However, I’ve found that the Alpha jacket (the one with the double front) is a bit better for cold days up in Scotland as the lining gives it a bit of extra insulation, but its nice being able to unzip the outer fully when riding up hill without exposing your sweaty baselayer to the chill. An alpha with a Flanders LS will see me down to about zero. Any colder and its double baselayer time.
    #929823
    df280
    I’ve found the BTWIN 500 Warm
    I’ve found the BTWIN 500 Warm Cycling Jacket from Decathlon to work okay below 10 degrees, tend to get it out when the baselayer, short sleeve gabba and arm warmers combination starts to not be quite enough.
    It’s not the most breathable so not ideal if you’re going out beyond a couple of hours, but on the other hand is a bargain compared to some competitors. Also I’ve had it a few years and it’s still going strong so good longevity.
    #929821
    vonhelmet
    DHB soft shell from wiggle is
    DHB soft shell from wiggle is good and doesn’t cost the earth, unlike a lot of soft shells.
    #929817
    Recent Perfecto user here,
    Recent Perfecto user here, really like it, “perfect” for the temperatures right now, once it gets chillier the Pearl Izumi elite pursuit will be worn, did me right down to the beast last March.
    #929815
    Stratman
    I’ve happily used a long
    I’ve happily used a long sleeve Gabba (now Perfetto) for years, with a long sleeve merino base layer (endura baabaa) down to around freezing.  I tend to run hot as well.  I’ve also got an Alpha jacket that is good for even colder with a short sleeved baabaa.
    Stolen Goat Orkaan looks good, I’ve never tried one, but I do have one of their long sleeve jerseys which I’ve enjoyed.
