- This topic has 22 replies, 20 voices, and was last updated 7 years, 8 months ago by
matthewn5.
October 4, 2018 at 11:47 am #29018
tommyraleigh
I’m having a bit of a dilemma on my commute with the changing seasons!
Last week and going into Monday it was pretty nippy out so bib tights and a light jacket with gloves were fine… I stick on similar gear on Tuesday morning and it’s about 8c warmer, probably the hottest I’ve ever been on the bike! What I want to know is, how does everyone else deal with the changeable weather this time of year? I also have a big downhill at the start of my route and then it’s flat/slightly uphill the rest of the way, so I can either start out pretty cold and warm up or start warm and end up real sweaty. Do I just have to get good at removing a layer mid-ride? Help!
matthewn5
I’ve got a pair of (non
I’ve got a pair of (non-cycling) Columbus Sportswear windproof gloves that are perfect for this sort of weather. They have a reflective foil lining, palm and finger grippers, and you can use smartphones with them. And on sale at the moment:
https://www.columbiasportswear.co.uk/mens-trail-summit-running-gloves-1749501.htmlRapha Nadal
Armwarmers, kneewarmers,
Armwarmers, kneewarmers, gilet, light full finger gloves, oversocks.
Pretty much essential items during the spring & autumn transitions.
nniff
Pretty much what everyone
Pretty much what everyone else has said. A pocket-sized gilet is the most useful piece of clothing, plus LS baselayer (I can pull the sleeves up if need be), ordinary jersey, arm warmers, and either bib shorts and knee warmers, or calf length bibs from Decathlon (the former if it’s going to be warm on the way home). Arm warmers and gilet usually get removed at about the 20 minute mark (after a big descent, which is always a delight last thing on the way home)
Mungecrundle
I’ve been looking at too many
I’ve been looking at too many “Close Pass of the Day” videos and have a whole new wardrobe. I’ll just add some extra padding to keep out the winter chill.
Redvee
Still in shorts at present
Still in shorts at present and short sleeves though this is with arm warmers some days and have added a mesh base layer. Will make the switch to full sleeves in November along with knee warmers or 3/4 bibs, this also means swapping the drawers around. My kit is divided into winter and summer drawers.
My wardrobe above was based
My wardrobe above was based on the crazy changes in temperature of the past few days down on the South Coast. Waking up to temperatures of 8 degrees for the morning commute and nearly 20 for the ride home.
If it is wet and cold then my choice of clothing would definately change and so would my choice of footwear. Overshoes instead of oversocks as ClubSmed points out for example.
Met Office.gov.uk local
Met Office.gov.uk local forecast the night before and, if unsure, a morning check of the latest Met Office readings from the local weather station (about 2 miles from my workplace). I prefer to put up with feeling a bit brrr! for the first mile or so because I find it much more tolerable than being too hot by half way.
11-15°C normal jersey with arm warmers and either knee warmers or 3/4 tights;
< 11°C lightweight windproof jacket, cycling cap (easily removed once warm);
Below about 8°C long sleeve merino baselayer under the jacket and full length tights.
For your start I’d perhaps a gilet might be worth a try. A 5p carrier bag under the jersey or jacket is an emergency/cheapskate way of keeping cold air off your chest.
There are so many variables
There are so many variables it’s hard to say at x temperature on x type of ride/ride intensity that you will definitely wear x clothing each time. Even relatively small differences in temperature/other weather, effort, how you are feeling can change what you feel you need to wear. I’m far less susceptible on my legs than upper body, I think that’s fairly normal however.
But that said,10C-16C it’ll be shorts (this could be my sports or walking shorts which I use a fair amount for commute/utility) and anything from a std short sleeved jersey to a long sleeve thin jersey if it’s closer to 10C, it could also be a thin short sleeve jersey with a spring/autumn jersey if there’s a bit of wind and/or closer to the lower temps. I might wear my 3/4 bibs or longs just because they’re to hand and a biting wind or knowing I’m coming back late when it’ll be much lower temps and setting off ‘cold’ with a short journey, will draw me more toward them, also my longs tend to be a bit more modest in terms of sitting with friends.
I did buy some arm warmers last year for the first time but I’ve worn them once, it just seems hassle to put them on when you’ve a thin long sleeve top you can put on.
I think we all have a ridiculously large wardrobe with many garments for different occasions/temperatures/weather
Stratman
I’d agree with start cold and
I’d agree with start cold and warm up. It can take 3 or 4 miles before my hands get comfortable.
Another one for Castelli, I’ve pretty much fine tuned my setup now, although I do tend to run hot. I just open the zip to cool down if I’m in a windproof.
- cold ish and damp Gabba, endura baabaa ss and arm warmers, omloop thermal bibs (high single digits)
- dry, swap for an alpha wind jersey (today) or a LS stolen goat (not windproof)
- colder and wet or dry Perfetto and ss baabaa, sorpasso 3/4 (low single digits) Planet X 365 gloves
- cold and wet or dry Perfetto, full length sorpasso and LS baabaa (very low single digits to zero) same gloves. On a long ride (200k) in these conditions I used a pave waterproof and a LS stolen goat as I knew a gabba or alpha would wet out.
- very cold, full length sorpasso and alpha jacket with ss baabaa (down to -7 so far) warmer gloves.
Always Shimano goretex mtb shoes with merino socks and endura overshoes.
There’s quite a lot of overlap in the comfortable temperatures for these, so it generally works well enough.
dottigirl
3/4 are brilliant for this
3/4 are brilliant for this weather.
Chris Hayes
Tights for the first time
Tights for the first time since April this morning… plus a 20yr old Assos windblock jacket that won[t die. They’re all set out for tomorrow morning’s ride too. With overshoes. It’s cold at 5am…
srchar
Shorts and a Castelli
Shorts and a Castelli Perfetto from now until winter starts to bite, then shorts, leg warmers and an Alpha ROS.
The Castelli jackets are good. Really good.
alex1987
Never tried the Castelli
Never tried the Castelli stuff (Gabba/Perfetto) but I have a Gore Windstopper jersey and love it. It’s short sleeve and in that and with a pair of arm warmers (mine are sportful no rain, which like the jersey are good in light rain as well and feel windproof) I’ve ridden in temperatures between 4 degrees to late teens.
Choice of shorts/tights, gloves and potentially base layers to fine tune to taste and stick a packable softshell/gilet in the back pocket to cover a LOT of grounds! Works for me, anyway 🙂
Canyon48
When its cold (but not REALLY
When its cold (but not REALLY cold) I commute in wearing bib shorts and a long sleeve jersey with thermal leg warmers and a merino baselayer (and merino socks with thick gloves).
When it’s chilly, I wear the above except I don’t use the leg warmers and use a lyrca baselayer instead of the merino one (and some thin full finger gloves).
When its absolutely freezing, I wear thermal tights, merino baselayer and a thermal jacket.
Obviously, when the weather is like it is, it can be frustrating because I have to take extra (thinner) baselayers/gloves to wear on the commute home. And it’s further frustrating as what I wear will change day to day.
Once you have 4 variations of kit for; supercold, cold, chilly and fair weather conditions – it’s fairly easy to wear the rights stuff – guessing the weather and making sure the right combination of clothes is washed for the next couple days is the real challenge!
CXR94Di2
Just bib shorts and shoes,
Just bib shorts and shoes, nothing else. Don’t go outside on UK roads from September till April. Conservatory is my road and this
