Seasucker plus mudguards
  • This topic has 6 replies, 6 voices, and was last updated 8 years ago by Dr_Lex.
  • #28978
    rdmp2
    Like the look of the seasucker roof racks- anyone know how they play with full guards? Obviously depends on geometry but is the bottom of the front guard likely to hit the roof? Do spacers move the bike high enough to clear? Also I imagine without the front wheel the front guard is effectively a huge parachute straight into the wind. Likely to be any problems with that at 70mph?
  • #927811
    Dr_Lex
    rjfrussell wrote:
    on subject of seasucker-  is there any conversion kit for thru axles?
    yes, although I bought the 15mm one and put a reducing sleeve in for my 12mm axle. As sea-sucker lack UK distributor, it wasn’t worth buying the 12mm direct.
    As noted regarding mudguards, you’ll need to check your set-up; my partner’s bike has ‘guards that just brush the roof, so wedge in a piece of foam, as it’s short distances on 50mph limit roads. You could probably fashion a riser block without compromising safety.
    #927809
    rjfrussell
    #927807
    nniff
    I’ve got a bike with
    I’ve got a bike with mudguards that fits happily on an estate car roof.  Best thing to do is to run a straight edge from the front QR to the bottom of the back tyre and see if it clears the mudguard.  Then take into account the two inches of extra height in the seasucker.  THe biggest problem is a pedal/crank touching.  I tie one crank to a chain stay with a length of old inner tube to make sure it can’t rotate.
    That bike won’t fit on a BMW Z4, because the front suckers are on the roof and the rear one is on the boot.  Bikes without mudguards fit no problem (same caveat for cranks, but more so)
    #927805
    rdmp2
    @canyon thanks, as I thought
    @brooksby err…
    #927803
    I saw the headline for this
    I saw the headline for this and thought we had a Grant Peterson acolyte on here asking about seersucker… yes
    #927801
    Canyon48
    I have to take off my front
    I have to take off my front mudguard when I put my bike on the seasuckers as it hits the roof.
    I also think 70mph is just a tad too much for a mudguard!
    As you have to take out the front wheel anyway, taking off the mudguard isn’t too much of a hassle.
