- This topic has 11 replies, 10 voices, and was last updated 8 years, 1 month ago by
FatAndFurious.
September 20, 2018 at 1:05 pm #28969
snappyandrew
I use ridewithgps.com but have the problem that it sometimes sends me down bridlepaths/gravel stuff that I don’t want my pretty road bike going anywhere near.
Is there a good way round this?
I only ride road bikes so want to keep to the paved stuff
What else do people use?
FatAndFurious
I use ridewithgps in “driving
I use ridewithgps in “driving” mode as per Mathemagician’s comment.
I find it will put route control points on tiny side roads which you can’t actually see when plotting out the coarse route. I’ve got into the habit of reviewing my plotted route and zooming in on my markers and checking that they’re not some side street or bridleway.
Overall, I find it an excellent planning tool with realtime altitude profiling a real plus. Don’t know if you’ve sufferred from this, but it took me months to realise that there are Undo and Redo buttons in the top right corner of this profile, so getting an inadvertant control point added when I just wanted to drag the map around isn’t an issue any more!
watlina
I’ve used most of the route
I’ve used most of the route planners out there but still find RWGPS the most flexible and powerful to use.
If your routing over areas you don’t know then as iso2000 says a few seconds dragging the little person over to spot bits of the route that don’t turn blue is a good check as it means the Google car didn’t go down there. You can then quickly check that area with Streetview to see what it looks like all from within the website. It’s also worth changing between the different map types as the routing will have subtle differences between each one.
Map: Google Maps, this is the default map used when viewing a ride, route, or planning a route.
Bike Paths: Click this button just next to the map selector to display the bike path info. This button only works on the Map view by Google.
Map: Google Maps with Terrain. Check the Terrain box to view contours of the map.
Satellite: Google Satellite Imagery – this is useful for determining the width of a road and pavement type.
RWGPS: Ride with GPS Maps based on Open Street Maps.
OSM: Open Street Maps. An open source map that covers the entire world. Anyone can submit changes to OSM.
OSM CYCLE: A variation of Open Street Maps. http://www.opencyclemap.org/
OSM OUTDOORS: Open Street Maps with elevation contours.
ESRI TOPO: ESRI Topographic maps.
USGS TOPO: United States Geological Survey Topographical maps.
USGS SCANS: Scanned maps by the United States Geological Survey.If you’ve got a Garmin that can have IQ apps then with routeCourse you can get the route across wirelessly or just plugin and copy over the TCX or GPX. Turn by turn has always worked for me on routes I’ve done in RWGPS.
CXR94Di2
Strava whilst not perfect,
Strava whilst not perfect, non of the gps mapping are, is good because it plots routes that lots of cyclists have used. I do a quick plot with strava, then check it for busy A roads, cross check it with a NCN (national cycle route) and further check it on Google Maps using street view if anything looks unusual.
That is how I’m building my route across the UK for my own Jogle.
buy a paper map or download
buy a paper map or download them and plan your route in advance, write out a pictorial route on a small bit of paper you can keep in a jersey pocket in case you forget whwere you are going.
This is a foolproof system, you’ll never run out of battery power or a signal and absolutely will avoid routes you don’t want to go down.
iso2000
I prefer ride with GPS to the
I prefer ride with GPS to the others people have mentioned. To check that my route sticks to the road I click the street view icon (the little person) and the roads are highlighted in blue as these have been photographed by Google.
NorthEastJimmy
I tend to use strava to find
I tend to use strava to find new routes as it’s got the best data for popular routes actually used by cyclists.
I use plotaroute.com to be able to send the file to my garmin fenix with turn by turn instructions. I sometimes have to switch from ‘car’ to ‘bike’ or to ‘manual’ when it tries to auto plot to avoid what it thinks is a motorway or trying to send me on bridal paths. Fairly easy and quick once you used it a couple of times, and free!
Mathemagician
If you switch the mode from
If you switch the mode from cycling to driving, that will avoid cycle tracks and bridleways…just be careful it doesn’t send you on a motorway or similar. You can check a box for “avoid highways”, but I don’t know how effective it is- I tend to know most of the roads I want to avoid so I don’t need to use the feature. Hope this helps.kil0ran
vonhelmet wrote:It’s only as good as the underlying maps. Google maps seems to be very optimistic in terms of what is navigable by bike.Komoot is crowd-sourced to a certain extent. Brilliant for gravel and cross-country, and also for finding bike paths. The roadie mapping is solid too, but it excels at the non-road stuff.
vonhelmet
kil0ran
I use Komoot, you can set
I use Komoot, you can set preferences and it will tell you if there’s any unpaved stuff on a route – and highlight it on the map. Then you can manually adjust the route if needed. I’d say it’s selling point for me is the fact that it will find bridlepaths and the like so it might not be ideal, but it’s by far and away the best bike-specific nav I’ve used. It will always seek to route you away from traffic for example. Admittedly on a recent ride that let me do a mile of Strada Bianche chalk down action on my road bike on 25s!
CXR94Di2
Strava I use. There is
Strava I use. There is komoot and cycle.travel
