Claris with 105 Cassette
  • This topic has 2 replies, 2 voices, and was last updated 8 years ago by OttoS.
  • #28924
    OttoS
    I’m looking for a cheapish road bike to use on an Elite Direto direct drive trainer. Will a bike with Claris (or Sora) work alright with the 105 cassette I’ve got on the trainer? I know the trainer is only compatible with 9/10/11 speed Shimano but if the cassette is ok will the rest be ok??
    thanks
  • #926855
    OttoS
    Thanks for this, pretty much
    Thanks for this, pretty much what I suspected. I’ve read that an 8 speed cassette with a spacer works ok so might need to give that a shot.
    Thanks again
    #926853
    Canyon48
    Assuming you are talking
    Assuming you are talking about the most recent groupsets…
    Shimano Claris is 8 speed, Sora is 9 speed and 105 is 11 speed.
    None of these is compatible with another, you can’t mix and match speeds because of the different pull ratios.
    Your only option is to use an 8 speed cassette on the trainer, with a spacer – this should work – can anyone confirm this though?
