- This topic has 7 replies, 6 voices, and was last updated 8 years, 2 months ago by .
Hi Folks,
Typically the Elite Directo is comparable to the Tacx Flux and the Cycleops Hammer is compared to the Neo, Kickr, Drivo but as it happens I have the budget for either Direto or Hammer at the same price for £500 +- change.
The Hammer is technically considered the higher end but the increase in resistance and gradient simulation is not as high on my priority as sound, accuracy, general feel.
I do hear good things about the directo which is why I am wavering on the choice.
I use 4iiii left crank PM on my bike and I know I can use that so that my numbers are comparable both inside and out but I will probably change to a cheap powerless frame on the trainer and maybe use the offset on the 4iiii to try match the turbo power for consistency and you have the option at looking at LR balance on the direto.
So…what would your choice be noting that the other “high end” turbos are out of budget and I’m not considering the flux?
Appreciate your feedback!
