Bike rental for Pyrenees. Anyone have a bike to rent?
  • This topic has 9 replies, 5 voices, and was last updated 8 years ago by darrenleroy.
  • #28870
    darrenleroy
    Silly question but does anyone have a bike they might want to rent a 5’7″ rider? My Bianchi has a 10 speed rear cassette that only goes to 25 and I’m sure I’ll need a 32 biggest rear cog. It will cost me a fortune to replace my rear cassette, wheel and derailleur so I wondered about hiring a bike for the two weeks I’m out in the Pyrenees. I could rent one out there I suppose. Any advice or private owners willing to rent their spare bike? Have £200 to spend.
  • #926007
    darrenleroy
    Duncann wrote:
    darrenleroy wrote:
    darrenleroy wrote:
    srchar wrote:
    darrenleroy wrote:
    Unfortunately it’s a Campag 10 speed, thus all the pain.
    Miche do 13-30 and 16-30 10-speed Campag-compatible cassettes, which the Cycle Clinic will sell to you for £32.  I doubt you’ll notice the difference between 30T and 32T.  It is also reasonably likely to simply work with your short cage mech (I’ve run a 32T cassette on a Chorus short cage mech).  £13.49 for a KMC X10.73 chain from Wiggle, including free Haribo, and Robert is your mother’s brother.
    Thanks very much for the input. Appreciated.
    Why would I need to change the chain? (Probably a silly question)
    Two possible reasons, I think:
    1. with a bigger rear sprocket (esp if it’s a 32t) you might find your chain is no longer quite long enough to stretch around the largest chainring and the largest sprocket. You shouldn’t be ‘cross chaining’ like that anyway but it can happen
    2. your current cassette and chain will have worn together. Putting a worn chain on a new, unworn cassette will make the latter wear faster, and it might skip under load on the smaller sprockets.
    Neither of these may apply in practice – but I’d hazard a guess are why schar suggested it.
    You’re quite right about chain length. And my chain is a bit worn so it’s time for a new one. Just ordered a new medium length 10 speed Veloce and a 16-30 cassette from The Cycle Clinic. Mr Borg was very helpful. I’m not going to get that extra couple of teeth but I’ll just have to harden up a bit. Thanks for you help.
    #926005
    Dnnnnnn
    #926003
    darrenleroy
    #926001
    darrenleroy
    #925999
    maviczap
    Depending on where you’re
    Depending on where you’re staying, then this rental place comes recommended
    Its in Luz Saint Savuer, at the bottom of the Tourmalet
    http://www.tourmalet-bikes.com/rental/?lang=en
    I haven’t rented, but others have on the recommendation of Les Sorbiers where I’ve stayed this year
    http://www.lessorbiers.co.uk/
    If not you can get a Road Fairy or Wolf Tooth to turn your mech into a long cage
    https://gearmechhanger.com/S14-Alpe-DHuez-Road-Fairy
    https://www.sigmasports.com/item/Wolf-Tooth-Components/Road-Link-Rear-Derailleur-Hanger/DOQG
    Then your mech can handle a bigger cassette with no problems, so all you’ll need is the cassette & chain
    #925997
    Dnnnnnn
    You can buy individual Campag-compatible sprockets, e.g.
    Note that the last position sprocket on a 10sp Campag cassette may be ‘dished’ so that it sits closer to the spokes. If that’s the case with your current biggest (27t) then you’ll need to swap the last two spacers around, or replace your current 27t with a ‘flat’ (i.e. undished) sprocket, e.g.
    IIRC, I bought a single larger sprocket from acycles and it’s been fine. Arrived fairly quickly despite coming from France.
    For the price of two sprockets, you might be as well buying a new cassette though (especially if has an even bigger range).
    #925995
    srchar
    #925993
    darrenleroy
    #925991
    Assuming your 10sp is Shimano
    Assuming your 10sp is Shimano…
    you won’t need a new wheel
    Wiggle have Tiagra 11-32 (and even 11-34) 10sp cassettes for £21
    a new chain will cost £15 (Wiggle)
    IF you need a new derailleur a Tiagra (with GS cage) level will cost £26 (Wiggle)
    So, for less than £70 you can have your bike ready for the Pyrenees. With the other £130 you can buy a lot of beer for the end of day celebrations
    can’t do it yourself? buy the bits and get your LBS to install for another £40 – either way your miles ahead in costs
