Gear Ratios For Turbo Trainer
  • #28794
    ibr17xvii
    I want to put a bike on my turbo but the gear ratios don’t match – I have a 11/28 cassette on the turbo but 11/32 on the bike.
    Aside from removing the cassette on the turbo & replacing it with a 32 what’s the easiest way round it?
    I was thinking of taking the chain off & putting a shorter one on specifically for the turbo but wasn’t sure if that would work & if the rear derailleur would need adjusting or be compatible with the smaller cassette.
  • #924547
    Canyon48
    ibr17xvii wrote:
    Canyon48 wrote:
    ibr17xvii wrote:
    Canyon48 wrote:
    You don’t have to worry about the cassette not having the same range.
    An 11-28 cassette will work absolutely fine with a bike that is set up for 11-32. Nothing needs adjusting at all, it will all be fully compatible (assuming it is all the same speed).
    There is only a problem if you do the opposite and try to fit an 11-32 cassette on a bike that is set up for 11-28. However, in your case, everything should be compatible and the chain will not need changing.
    Really?!?!?! All sounds far too simple……..
    I just presumed it would be a right faff with the different ratio.
    They are both 11 speed so maybe just a little tweak of the barrel adjuster & should be good to go?
    It really is that easy 🙂
    You shouldn’t even need to adjust anything at all, not even the barrel adjuster.
    My Whyte Wessex has 11 speed 11-32, I can run it with a different wheelset which has an 11-28 cassette if I want, without a single issue.
    Sounds good, hopefully it really is that easy!
    Thanks for your help mate.
    No problem 🙂
    The 11 speed components are much more reliable in my experience and don’t seem to be so susceptible issues when changing cassettes/gears.
    #924545
    ibr17xvii
    #924543
    Canyon48
    #924541
    ibr17xvii
    CXR94Di2 wrote:
    CXR94Di2 wrote:
    better still, Zwift, bigringVr, have a difficulty setting. All this does move your gearing, so you can use for example 53/39 with a 11-28 and still be able to cycle up Alp d’ Zwift. Zwift works out the speed and resistance from your power meter. You down have a power meter/Decent smart trainer?
    Yeah I have a Wahoo Kickr that I use all the time with Zwift but not considered that.
    So basically instead of physically changing gear on the bike adjust the difficulty setting on Zwift?
    #924539
    CXR94Di2
    #924537
    ibr17xvii
    #924535
    Canyon48
