Removing frame etching
  • This topic has 10 replies, 7 voices, and was last updated 8 years ago by Spangly Shiny.
  • #28761
    srchar
    Local plod made a mess of etching my frame.  I’m slightly miffed but can live with it, as it’s on the bottom of the downtube.  However, it makes my bike look stolen, like I’ve tried to remove the etching.
    I suspect I’m looking at covering it up with a sticker or something – unless anyone knows if it’s possible to remove it by chemical means, without muffing up the paint?
  • #924055
    Spangly Shiny
    Depending on how thick the
    Depending on how thick the paint coat is you may be able to polish off the marks down to clean paint then apply some clearcoat.
    Failing that you are looking at a respray I fear.
    #924053
    srchar
    Mark B wrote:
    But the black marks that you don’t want are presumably not indentations? So some kind of solvent might remove them while leaving the indentations that you want?
    Sorry – should have been clearer – the marks I don’t want were made by the same substance.  The bloke who applied the number realised he’d cocked it up halfway through and tried to “rub off” the fluid (acid?).  He actually just spread it around a bit, so those marks are now etched into the paint.
    #924051
    Tjuice
    janusz0 wrote:
     Your local(ish) hardware shop or a decorator’s store will sell expensive tins of pure acetone.
    I always buy acetone in a small bottle from the local chemist (good for dealing with tubular tyre glue).  Don’t recall ever paying more than £4 for a bottle.  And a quick look on Amazon shows you can get 250ml for £3.24.
    No idea whether it will stand any chance of removing the marking on your frame though.
    #924049
    Mark B
    #924047
    Mark B
    #924045
    srchar
    SteveAustin wrote:
    You cant remove it, thats the whole point….
    Looks that way. On closer inspection, the marking isn’t a paint layer on the surface of the frame, it’s actually made up of small indentations – it has gone through the clear and the first layer of paint.
    #924043
    SteveAustin
    #924041
    janusz0
    Some nail polish removers
    Some nail polish removers contain a little acetone, but you wouldn’t want to use pure acetone on finger nails.  Your local(ish) hardware shop or a decorator’s store will sell expensive tins of pure acetone.  The main ingredient of nail polish remover is ethyl or amyl acetate.
    Nonetheless, I presume that this bikeregister marking is designed to be indelible,  I’d guess that any solvent that removes the dots, will also remove the paint, making your frame look even more stolen:)
    #924039
    StraelGuy
    Try acetone aka nail polish
    Try acetone aka nail polish remover but check on an inconspicuous area first it case it damages the laquer.
    #924037
    srchar
    The offending etching:
