- This topic has 37 replies, 17 voices, and was last updated 8 years, 1 month ago by
Canyon48.
July 4, 2018 at 4:17 pm #28687
darrenleroy
Has anyone ever decided to go sub compact, say 48/30, rather than change the rear cassette?
I have moved to hill country. My rear cassette is 12-25 and I struggle on some of the steeper ascents. I have a compact on the front.
I have a Record rear derailleur (short) that won’t cope with a larger ranging cassette. Instead of changing the rear derailleur and cassette I wondered if going to a sub compact would give me the equivalent of being in the 32 teeth sprocket?
I am crap at maths and struggled to grasp the tables that work it out for you.
CXR94Di2
photo XTR Di2 triple with 48
photo XTR Di2 triple with 48/36/26 gearsCXR94Di2
maviczap wrote:Back on topic.My first trip to the Pyrenees I used 9 speed triple 50/39/30 with 28 biggest. I was able to spin up the climbs, as a rider from flat East Anglia, I was able to climb better than my mates from Wales who were on compact. To be fair they were carrying more body weight than my 67kg
Next few years were on 10speed 50/34 with a 30, which I managed, but couldn’t spin up like the triple.
Upgraded to 11speed and the last 2 trips, I used a 50/33 with 32, but probably due to a lack of miles ,getting older and weighing 70kg I did struggle on my last trip.
I’m back in the Pyrenees next weekend, and ilI’ be using 46/32 and a 34, with more miles and weighing 67kg, so let’s hope I can spin up, rather than grind up.
I’d quite happily use a triple but I’m using Di2, anyone using Di2 with a triple, and I don’t mean using 2 two of the three?
I have in my parts locker, a Tiagra triple and 105 triple shifter, which will be deployed once age overtakes ability, which won’t be long
The gearing you found easy for the Pyrenees was down to your weight. Ive ridden with a variety of riders of different weights. Light riders, sub 75kg, can get away with compact 50/34 11-28/32 setups when climbing mountains. When heavyweight riders try mountains they need alot easier gearing, I go upto 40t cass and now a 26t chainring to be able to spin for hours. Ive seen 90+kg riders die a horrible slow grind death using a standard compact setup. I weigh 94kg+bike+kit so easily nudging 110kg whilst climbing.
Ive just come back from the Alps and was able to maintain a decent cadence of 80rpm for the like s of the Glandon, Galibier and Croix de fer, These are climbs of 25+km long average 7+%
Note
light riders will climb faster than heavy riders on long climbs. Either let them go or leave 10 mins earlier to meet near the top.
I and another chap left 15 mins earlier for the Croix de fer, we were caught up within a km of the top some 30km long climb
CXR94Di2
Yes
I built my Tripster V2 last year for mountain climbing using XT di2 groupset, initally with 40/28 crank, a 11-32 or 11-40 cassette. I modified to get 44/28 crank to give a little more flat down hill speed.
Ive now changed my front Di2 XT 2 gear derailleur to a XTR Di2 3 gear. These are fully compatible with my set up. I then fitted an XT triple crank 48/36/26. It works beautifully either in syncro mode or manual mode.
Shimano spec is that XTR will only take 40t max crank, this is rubbish as 48 fits easily. Ive hear of 50t triple cranks being fitted with careful setup.
Having a band clamp for the front di2 derailleur is recommended so to allow fine adjustment
Here is shimano compatibility chart and a photo of my new crank with XTR di2 derailleur
maviczap
Back on topic.
Back on topic.
CXR94Di2 wrote:darrenleroy wrote:BehindTheBikesheds wrote:get a compact triple, 50/36/24, solves all your problems and you can keep the 11-25I’m not getting a triple. I mean, I’m not Peter Sagan cool, but I have some dignity.
The word is vanity.
What ever get you up the hills in the most comfortable way
Absolutely, many a time I’ve watched pros come to a standstill and almost falling off due to running out of gears. Tour of Britain a couple of years back and suprisingly it was raining in the Lake District, watched with great hilarity as an old codger with a walking stick outpace the chasing bunch up a wet steep bit., it was comedy gold
darrenleroy
The word is vanity.
You’re quite right, it is vanity. Last summer I met a middle aged Belgian chap in Le Bourg-d’Oisans who was doing some riding, He had a triple on the back. At dinner I was sat next to a British marine and his girlfriend (ex-Wales international runner turned very keen cyclist). The marine fancied himself a bit; you know the type; buff, very focussed, very dull.
We were comparing times. When the Belgian chap told us his time the marine went quiet. The Belgian was riding a triple. He explained that it allowed him to spin at his preferred cadence whatever the incline, thus maintaining rhythm. I’m still not fitting a triple though.CXR94Di2
The word is vanity.
darrenleroy
bobinski
I changed from a 50/34 to a
I changed from a 50/34 to a 48/32 with 11-28 for mountain riding. I thought close enough to a 50/34 11-28 without need to swap cassette and rear Ultegra short derailleur. It wasn’t enough and I ended up swapping in an 11-32 as well. What a huge difference. Had already ruined my legs at a cadence of 70 but now better able to spin at 75-80. No issues using short cage at all.
The other riders were using a minimum of 50/34 and 11-32 or even 34
CXR94Di2
I’ve got a triple crank to
I’ve got a triple crank to fit 48/36/26 with Di2 when I return home. I will run either a 11-32 or 11-40 Cass. I’ve been using a twin crank of 44/28 in the Alps this week and has been perfect for me to sustain 80rpm all the way up climbs like the Galibier with my 94kg weight.Anonymous
alotronic
VeloUSA wrote:If you decide on a Wolf Tooth Roadlink ensure the seller accepts returns because Wolf Tooth says* Compatible only with Shimano 10- and 11-speed rear derailleurs
* Not optimized for or recommended for use with other brands.
https://www.wolftoothcomponents.com/pages/roadlink-tech-page
Sorry, missed that the OP was talking Italian – worth a search to see if they work then!
madcarew
darrenleroy wrote:herrkaa wrote:I have a Chorus with a short cage and I’ve been running a 12-29 Miche cassette for years without any issues. Are you quite sure that your Record won’t cope?I’m not 100 per cent sure but my LBS has said it won’t. It’s quite a jump from 25 to 29. My rear derailleur is already pretty stretched out in the 25 cog.
I’m thinking I will have to replace the rear derailleur and cassette. Bummer. I might just go the whole hog and change up for an 11 speed Potenza. I hate wasting equipment that works perfectly but I suppose I could try and flog it on eBay.
It would be a rare derailleur that can’t cope with an 18 tooth difference in the back. If your derailleur is already stretched out on the 25, it may be that your chain is too short.
Going from Standard to sub compact will give the equivalent of a 27 on the back (1 more gear) and going to a full compact will give the equivalent of a 29 on the back ( 2 more gears). TBH, going full compact at 34/50 would be a good result, but for an awful lot cheaper, a 12 – 29 cassette would achieve a better result (you’d lose 1 top gear, but it doesn’t sound like you’re bothered by that having suggested a 48 would be ok). Get another opinion from a different LBS before taking the plunge on a new chainset. You can probably find the capacity of a record derailleur on line.
VeloUSA
maviczap
alotronic wrote:Cheapest way to get where you want is leave the 34/50 on the front and buy a £20 ‘road link’ which is a thing that sits on the end of your mech hanger and pushes the rear mech further down. You can then use a 36 or even 40 as biggest sprocket on the back via a MTB cassette – gives you the same range as a subcompact with a 12-28 or 12-32. I put one on my bike for some welsh hills last week for a 34 x 36 granny gear and it worked a treat.This ⬆⬆⬆⬆⬆⬆⬆⬆⬆⬆
I’m running praxis works 46/32 chainrings on the front, and my Ultegra GS cage just about managed to run a SRAM 36t largest sprocket without a roadlink. With a roadlink copy installed, then no problem running a 36.
You can find these roadlink things on a well known auction site. The original roadlink things are overpriced for what they are, but cheaper than a new rear mech.
