- This topic has 21 replies, 10 voices, and was last updated 8 years, 1 month ago by
Welsh boy.
June 30, 2018 at 12:12 pm #28676
barbarus
Long story short, can I survive lightweight pannier touring with low spoke count wheels? Mavic ksyrium discs with 24 spokes, I don’t weigh much myself (76kgs)
Opinions? -
Welsh boy
barbarus wrote:
barbarus wrote:They didn’t collapse, not even loosened spokes and I didn’t even switch from 25s to 28s. Thanks for the advice all!That’s a shame, we all gave you bad advice in the hope that your wheels would fall apart miles from home and we could all have a little chuckle at your expense! Not really, glad you had a successful trip
barbarus
They didn’t collapse, not even loosened spokes and I didn’t even switch from 25s to 28s. Thanks for the advice all!froze
If those wheels will actually
If those wheels will actually support 240 some odd pounds then you’re more than fine, the only problem is that if one spoke breaks the whole wheel could taco vs a 36 or 40 spoke wheel would only require a minor truing of the surrounding spokes and you could still ride it.
I know that they can make strong enough wheels to tour on with only 32 spokes, but that doesn’t mean I buy into it for heavy loads. While they should hold up just fine, but depending on the weight you’ll be carrying it’s far safer over a long period of time to have 40 hole rim on the rear and 36 on the front, at the very least go with 36 rear and 32 front. You can take that anyway you want, no big deal, we all do things the way we want or feel safe in doing.
Read this site, it does say 32 spokes could be ok, but again I don’t agree with it, when I’m out on the road and far from some place that can fix a wheel I want my wheels, and other stuff I use, to be over engineered to reduce the possibility of failure to almost zero. It’s why on my main road bike (not the touring bike) I opted to put on the Enve 2.0 fork because while the the Enve 1.0 was lighter and even though it was rated 240 pounds and I only weigh 165, the 2.0 was rated for 340 pound rider, I wanted to make sure it would support me as well as impacts riding along at 20 mph into road ruts, railroad tracks etc without worrying about the fork. My touring bike has 40 spoke rear and a 40 spoke front (the factory was suppose to put on 36 and it’s spec’d that way in the catalog but for some reason it came with 40 spokes, but 36 would have been fine), currently I’m doing short tours but the stuff I have is going to work for longer tours I’m planning, but the weight of my load is only 45 to 50 pounds plus 25 pound bike and 175 pound rider with clothes on…which is always a good idea to have clothes on when riding a bike in public. Anyway here’s the site I promise a long time ago: https://www.cyclingabout.com/the-best-rims-for-bicycle-touring/
Even though I use 40 spoked rims I still carry a couple of FiberFix spokes because again I don’t want to be stranded someplace far from a bike store should a spoke or two break. Of course if you’re only ever going to carry 25 pounds or so than yes a 32 spoke rim would be fine depending on how much you weigh of course.
But you have to do what you feel comfortable with and if you’ll be traveling to remote areas, or if the surfaces you’ll be riding are going to smooth or rough.
kil0ran wrote:I ride RS11s as my winter wheels (20/16 I think the spoke count is) over potholed roads and I’m around 18st. Utterly bombproof, I think I’ve trued them once in three years riding.Don’t be going onto the CUK forum saying things like that they’ll string you up for intimating fewer than 36 spokes can work for heavier people! Just having that convo now and being called irresponsible ffs!
kil0ran
barbarus
Nah, if I buy new ones it
Nah, if I buy new ones it will be these https://www.rosebikes.co.uk/rose-hybrid-wheels-28700c-dt-swiss-545d-disc-shimano-deore-dh-3d37-disc-hub-dynamo-deore-fh-m6000-2665585
But I don’t really have the cash right now so going to chance it!Anonymous
if you take the std 55/45
if you take the std 55/45 split for weight distribution that gives you 66kg for the rear, you with nothing else are putting approx 42kg on the rear wheel. 10kg load still gives you a big margin, not all that rear weight loads directly onto the rear wheel either.
ATEOTD do what you feel is best for you so you feel assured.
barbarus wrote:
You also need to check the rack limit.barbarus wrote:120kg according to Mavic. But it’s the distribution that bothers me. I don’t have a suitable fork for front panniers so can’t spread the load.barbarus
120kg according to Mavic. But it’s the distribution that bothers me. I don’t have a suitable fork for front panniers so can’t spread the load.Anonymous
Chris Hayes wrote:Depends on how heavy your panniers are going to be. I guess the weight limit on those wheels are circa 90kg? They’d be difficult to fix by the roadside if you do have problems, so if you’re going to make a habit of touring some Open Pros or A19s might be more appropriate: at least then you’d have no concerns.you’d be guessing wrong, by a large factor.
barbarus
Yes, it’s not a long term solution and it looks difficult to even buy the right spare spokes let alone fit them. Panniers will be as light as possible!
Chris Hayes
barbarus
Great, this is sounding good.
Great, this is sounding good. When I do replace the wheels it will be with a hub dynamo set – I’m slowly rebuilding the modern version of the bike my dad forced me to ride in the 80s!
BehindTheBikesheds wrote:Don’t believe the BS surrounding the pitfalls of wider tyres on narrow rims …I’ve been running some tubeless 3 inch tyres on my mountain bike for years without any issues and they look just ridiculous on some old shimano rims. Slow as shit, though.
barbarus wrote:
barbarus wrote:Thanks for the vote of confidence folks! It was the weight distribution that was bothering me, plus the fact that the wheels are the first generation ones that were ridiculously narrow (pre wide tyre trend) so even 28mm tyres give a bit of a “light bulb” effect. At some point I’ll get some proper touring wheels but right now I just want to go without spending lots of money!Don’t believe the BS surrounding the pitfalls of wider tyres on narrow rims, it might look a bit odd but I’ve had a 32mm tyre on a silly narrow Mavic Open 4 which is on my commuter/daily, Even at my now Svelte 96kg plus bags/shopping and other bits I can hit a mini roundabout at 18mph to do a right hander and it not feel squirmy.
Someone your weight you could easily go 28/24 like a pair of Mavic Heliums, I did try a pair of DTSwiss 350/DT460s (rim brake) and were quite tidy, these are the disc brake variant.
