- This topic has 29 replies, 15 voices, and was last updated 8 years, 5 months ago by
Anonymous.
June 26, 2018 at 9:18 pm #28668
OldRidgeback
Just when you thought it was safe to go back in the water, I’m going to kick off another helmet debate with this bit of research:
Do I really want to do this? Well, ok. There may be some useful info in this one.
madcarew wrote:maviczap wrote:No matter how good the helmet, it does nothing to prevent the brain bashing against the inside of the skull, because of the massive deceleration forces involved in any crash. It will help prevent the skull breaking but not the bruising to the brain, and swelling of the brain which is what’s going to cause problems.That is precisely what it helps prevent, by providing a crumple zone, which provides a deceleration zone. Helmets aren’t to stop the skull being broken (the skull is much much stronger than a helmet) it provides a crumple zone, much like on your car. When your head hits the ground there is no deforming material that will absorb any energy, so the skull undergoes a massive deceleration (deceleration is inversely proportional to the distance available for deceleration) so if your helmet provides 5 mm of deformation compared to 1mm of deflection of your skull, then you have reduced the brain’s deceleration to one fifth. If the original deceleration was 50g, which is undoubtedly traumatic, you have reduced it to 10g, which is probably no more than banging your head hard against a table.
And yet so often we see broken/split/cracked helmets were that has not occured at all. That ‘crumple zone’ as you put it is sometimes effective at low speeds but only proven so in very strange and ‘best case’ scenarios, like falling onto the top part of your head onto a flat stationary surface from a walking speed and even then it will often not be enough to prevent a concussion or serious head injury. The vast majority of the forces will have been absorbed by the skull/brain.
The evidence proves precisely that helmets rarely ever prevent what you are trying to establish based on theoretical numbers in a lab/test environ which are rarely ever replicated in real life. this is in part why helmets fail so badly to have an effect on safety.
You cotinue to ignore the fact that many head strikes would never occur at all if a helmet were not worn, you continue to attribute any saved life/head injury as being the result of helmets just liuke Rich_cb does.
Again the data revealed in the Virginia study clearly states that despite big increases in helmet wearing deaths/injuries are at a high since 1991 and that almost half of all dead cyclists were wearing helmets, that’s hardly an indication of increased safety through helmet wearing is it?
Want to check the stats for Canada, I did, injuries/deaths have risen since helmet wearing became a thing, there’s a massively high % of helmet wearing in Canada, it’s not improved matters it’s made it worse.
Keep believing your hypothetical numbers, it’s total pony and the deaths and injuries to people on bikes keep mounting up, people like you and others are dangerous, not just to yourselves but the rest of us too and sadly that not just with regards to head injuries but all types of injuries as well as the other massive negative effects helmets have on people on bikes.
madcarew
Jimmy Ray Will wrote:Being a cynic… if I was looking to trick people into the importance of a piece of safety equipment, I couldn’t think of a better way than by making it more likely that a piece of equipment will be used when worn, and making sure there were obvious signs of its effectiveness when ‘used’.The humble bicycle helmet is beautifully marketed.
Increase the circumference of your head so you are more likely to hit it on things, then make the helmet super fragile so that its effectiveness appears obvious. I love the way the fragility of the helmet somehow perfectly encapsulates the perceived fragility of our heads. You genuinely couldn’t make it up.
At least full face BMX helmets and their ilk can genuinely provide some level of protection.
I keep seeing this idea that increasing the circumference of the head increases the likelihood that it will be hit. In the vast majority of crashes (and I’ve had a few) I really don’t see that increasing the head cicumference materially adds to the likelihood it will impact the obstacle. Does anyone have any research that shows that head strikes are more common in the wearing of cycle helmets due to the enlarged circumference of the head?
madcarew
Deeferdonk wrote:flobble wrote:Deeferdonk wrote:Jimmy Ray Will wrote:Cracked a helmet once, dropping it from waist height on to a flat surface. Are there any physics experts that could calculate the sort of energy a 250gram object falling from 1m would generate before impact? I can’t help but feel that it wouldn’t be a lot.Well thinking back to GCSEs
F =MA =0.25 x 9.81 = 2.45Newtons of force
Er, no.
OP asked for *energy*
Gravitational potential energy converted to kinetic energy = mgh = 0.25 x 9.81 x 1 = 2.45 joules
Whether that cracks a helmet depends a bundle of other things: the time duration of the impac (affects the decceleration and hence the force applied to the helmet), how concentrated the resulting force is, the shape of the helmet in the impact area, whether there’s prior damage you didn’t see, etc, etc…
Well, the energy it takes is a bit meaningless ( how many calories is your helmet rated at!?), so i interpreted what he really was asking for was force . As you go on to explain in your post, it’s the force and how its applied that is actually meaningful to the capacity of a helmet..
Actually it’s the energy dissipation that is important. The helmet is designed to work whilst wrapped around a head, not whilst empty. Hence Jimmy’s ‘test’ has no relevance to the efficacy of a helmet. It is highly likely that had the helmet been filled with a melon when he dropped it, it wouldn’t have broken, despite being 10 times heavier and the force 10 times greater.
Also, it is difficult to concieve that a helmet in good condition would break under the conditions that Jimmy describes, so it is possible, likely even, that it was already compromised.
madcarew
fukawitribe
maviczap wrote:No matter how good the helmet, it does nothing to prevent the brain bashing against the inside of the skull, because of the massive deceleration forces involved in any crash. It will help prevent the skull breaking but not the bruising to the brain, and swelling of the brain which is what’s going to cause problems.That is exactly what the research was investigating, as does some existing tests.
maviczap
Deeferdonk
Er, no.
fukawitribe
davel wrote:fukawitribe wrote:No, I don’t think there is no risk compensation in sport – quite the opposite .It’s an interesting topic. I’m not sure how much of this is strict ‘risk compensation’ and how much is just evolution of the game and other factors… but there are definitely unintended consequences of more padding, and I’d take a punt on some of it being attributable to risk compensation. It must be really difficult to measure in a competitive environment with risks being taken anwyay.
[snip]
Indeed – agree completely. The boxing one is interesting, and has a link with this study and MIPS – there is still a deal of debate about whether or not headguards caused more and/or differing injuries. One thing that came out IIRC was again the realisation that impact concussion is not simply the brain getting knocked back and forward in the skull, but there is a surprising rate of it due to tangential shots (which headguards can make worse). This was known for a long time elsewhere, e.g. in the army with oblique shot deflection from helmets, and is / was not at all obvious. If studies such as the one in the article can help hightlight such cases and get more – and better targeted – improvements in helmets as PPE from manufacturers, then I think that’s a good thing for those that choose to use them.
davel
But, a couple of examples:
Old school American Football having skull-caps to protect the head. Toughen up the helmets to become the motorbike-like ones they have today… players start tackling, ram-style, with their heads. Big news at the mo due to concussion, depression, and potentially massive lawsuits against the NFL.
Boxing: old-time bare-knucklers lasting 100+ rounds with few headshots due to the risk of broken hands. Today: 10oz+ gloves, 12 rounders (tops); broken hands are a regular scourge.
Amateur headguards were removed for male competition after 30 years of being mandated. The rationale was that they didn’t decrease head injuries – in fact, increased head injuries owing to less focus on defence and increased risk taking is one of the main reasons given: https://www.iseh.co.uk/news/latest-news/new-page-44
They now have the weird situation where women do wear headguards and men don’t, but, as the reason given for that is they don’t have the evidence for women yet as it’s a relatively young sport, and don’t just want to follow the men, it does at least hint at it being an evidence-based rule.
Close, but not quite the right equation there.
I found this site – The Splat Calculator: https://www.angio.net/personal/climb/speed.html
It seems to have trouble with putting in 0.25 Kgs, but it gives this equation for calculating the energy of a free-falling object:
Energy at splat time: 1/2 * mass * velocity² = mass * g * height
which gives: 0.25Kg x 9.8m/s² x 1m = 2.45Kgm²/s² = 2.45Nm
Oh – that’s your answer (excepting the units), but only because we’re using 1m as a height.
flobble
Er, no.
Deeferdonk
Jimmy Ray Will
Jimmy Ray Will
fukawitribe
No, I don’t think there is no risk compensation in sport – quite the opposite – although you may want to ask what age group the race was. I did wonder whether you’d ever watched BMX though, or remembered what it was like to be young, or combinations; it was quite interesting you thought you had much influence on how you fell in a BMX race which regard to head strike. You also might want to consider that risk perception and why people racing would want to take a potential performance hit against their competitors. Also have a look at the effect of anxiety on motor skills, a flip-side to over-confidence, interesting..
