- This topic has 5 replies, 2 voices, and was last updated 8 years, 3 months ago by .
looking for some help please.
I’m just completing my first bike build and I don’t know whether I should test the electrics first or fit bottom bracket.
All the cables are attached, except the front derailleur and I think it would be a good idea to switch it on, do and updates and check it’s all working before I fit the bottom bracket. But can I do that without the front derailleur on?
I don’t want to have to remove the bottom bracket if there’s a problem later. But I can’t fit the front derailleur properly until the chainset is on.
or should I just fir the front derailleur loosely now, check the electrics and then refit the derailleur once the chainset is on?
Also, where is the best place to put the smaller junction box? I thought I could wedge it better in the chain stay so it wouldn’t move but maybe it would be less likely to be affected by any moisture if it’s in the down tube?
grateful for any advice.
