Why no reviews for this very cheap bike with excellent specs
  • #28630
    Tomaz26
    Hello all,
    I cannot get Cube Attain GTC PRO disc 2017 in 56 cm so I decided to look elsewhere for a bike I could fit wider tyre on. Gravel bike. Found this one, but I cannot find any reviews. Specs look really good, full carbon, ultegra, for 1000 GBP? What am I missing? Ok breaks seems to be bad, but still mechanical disc. What bothers me is only 11-28 in the back, I think climbing with this bike will be hard. Other than that, some very good specs and I could not find better bike for this price, at least not full carbon + ultegra + wide tyre clearance + more endurance riding positions which is all I am looking for.
    https://www.merlincycles.com/blue-prosecco-ex-ultegra-carbon-gravel-bike-112970.html
    thanks for help
    Tomaz
  • #921753
    Vejnemojnen
    ChrisB200SX wrote:
    I’ve not seen that before, looks good. I’d suggest a compact chainset would be better.
    28T cassette on 34T ring is low enough for most. I’ve used my bottom gear for Streatley Hill when I was unfit, and possibly some bigger climbs in Surrey and up the South Downs from Eastbourne.
    36t inner ring classifies as compact. 46t outer ring is more than enough.
    a 12-28 cassette with 34t inner-46 outer could be even better
    #921751
    alotronic
    ChasP wrote:
    You’re missing the fact that you’re looking for a 56cm and it’s only available in 51cm and 53.5cm?
    Indeed, that would be just about a bit too small for me and I am 175cm, so unless OP is very short bodied and short armed the 53.5 (md) would probably not work…
    #921749
    ChasP
    #921747
    ChrisB200SX
    #921745
    Tomaz26
    Yep, this worries me. Front
    Yep, this worries me. Front and back 🙂 Compared to my current Cube Cross which has 26/36/46 and I use 26 front and 30 back on steep climbs..  Bike has 13 kg and schwalbe marathon tour plus tyres (950g) each, so this does make difference too I guess..
    Still not sure if this getting new bike is such good idea after all. Less gears and when I put light slicks on my hybrid it goes fast too, and without drop-outs so more leasure ride.. 🙂
    It is hard to have everything in one bike I guess 🙂 You either sacrifice speed, comford, off-road ability..
    #921743
    nortonpdj
    You could change the cassette
    You could change the cassette to a 30 or even a 32. And despite what Shimano say, both will work with a short cage if you adjust the b screw.
    #921741
    The Gavalier
    Bear in mind that it’s got a
    Bear in mind that it’s got a CX 46/36 chainset too.
