- This topic has 3 replies, 3 voices, and was last updated 8 years, 5 months ago by .
Dear all,
I have a dilemma. Currently riding Cube Cross hybrid bike with front suspension. At 38 years I finally decided to buy my first road bike. Now the problem is of course sizing. I do not have any chance to try those bikes in person so I have to buy on-line. I am 5.10 (177 cm) with long legs and short torso. My inseam is 86 cm, even 87 if I really push it in my crotch
I would like sportive bike with more relaxed position, because I would probably use this bike for 6 miles commute to work too (for 9 out of 12 months anyway..).The first one which I like Cube Attain GTC PRO disc 2017, which is discounted for 40 %. Problem is, only size 58 and 60 left. According to Cube table 58 should be ok for my height, although on the top of the range. So 56 to 58.. I think with my long legs and short torso I should lean towards lower number right, so 56?
Second queston is, how about female bike? I found a lot of great deals and I do not see why for example I could not buy Rose bike, female version. The only difference I could find is seat (which I would replace anyway). On Rose bikes frame geometry looks the same. If anything what I found out is that female frames have shorter reach as women tend to have shorter arms. So this would then actually benefit me right? I have long legs and short torso so women geometry I think would be fine. I found one bike which I like and which has almost the same specifics as Cube attain mentioned above has in size 56..
I also found Eddy MerckX Montreal 74 for crazy bargain price, but on this one I am not so sure. Everything else looks good in size L, but seat tube is failry short. Like 4 cm shorter than on other bikes with same geometry.. This is not good right? It would mean I have to put seat very high, which would then make me lean on handlebars and made my position very low and racy, which I want to avoid.. I think handlebar cannot be raise that much higher and shorter stem would not help much either here.
thanks for advice guys.
Tomaz
