- This topic has 64 replies, 29 voices, and was last updated 8 years, 6 months ago by
Anonymous.
May 16, 2018 at 10:52 am #28522
tommyraleigh
https://www.facebook.com/sussexpoliceforce/posts/1776482492397300
“Wearing a helmet saved my son’s life” – these are the words of a mother who’s backing our summer cycle safety message.
It follows the deaths of two cyclists in Sussex already this month. That’s two too many in our opinion.
In light of this, we’re urging all road users to ‘think bike’
As some of the commenters below have said already, there seems to be plenty of evidence to suggest compulsory helmet wearing does naff all to increase safety… also what have the two deaths got to do with the photo in question? Might have helped in that instance, but I doubt would have prevented the deaths! Seems a bit of a muddled message from the coppers.
Still in two minds about
Still in two minds about helmet use. Been using a cotton cap all week as I just sort of felt like it but this weekend I’m off on a climbing route and I’ll probably hit 50 on the downhills so I guess I’ll put the helmet on.
My mate has spent two weeks in a coma after a helmetless accident but he still won’t wear one so I guess once you’ve really made your mind up there’s no changing.
@madcarew – your point about
@madcarew – your point about helmet testing should be valid, but for one thing. Helmets are tested for hits against flat surfaces and not for irregular shaped objects. This means that a much weaker hit by an edge can cause a helmet to break in two and not provide any significant protection.
There is also an important point about the nature of the expanded polystyrene used in bike helmets – it is used for its ability to be compressed when hit and thus provide some protection. When you see a helmet split apart, that means that the polystyrene has failed in its tensile strength which is not a selling point of EPS (e.g. it’s easy to break apart polystyrene packaging, but difficult to compress).
Also, I’m not convinced by your figures on brain deceleration as I think you’re underestimating the size of forces involved when hitting another object at speed (AFAIK helmets are typically tested at up to 12mph). However, it is reasonable to assume that helmets would provide good head/brain protection for children due to their slower speeds and reduced height, although this could be offset by their increased risk taking if they believe that helmets are effective.
The big problem with talking about helmets as PPE is that it’s completely missing the point. We need to be looking towards the European countries that have much smaller cyclist KSIs; they have good cycle infrastructure and tend to not wear cycle helmets.
madcarew
don simon wrote:A couple of plod were seen riding around that there Liverpool (0-3 Real Madrid) today without helmets and conspicuously all in black with no hi-viz. You’d think that they’d take note of their own advice.Probably incognito, hadn’t filled out their whereabouts forms for UCI (a la Chicken Rasmussen)
don simon fbpe
madcarew
hawkinspeter wrote:By the way, I meant “naive” as in the mother’s views – I think most people on this forum have read at least some discussions of helmet efficacy.
A problem with using a destroyed helmet as a signature of a high level of protection, is that it leads to the paradox whereby the weaker the helmet, the more often it is judged to have provided protection.
My view on bike helmets is that they are good at protecting against scrapes and possibly minor skull fractures, but next to useless in preventing brain damage due to the brain ‘sloshing’ against the inside of the skull. Combined with the data that shows drivers give less space to helmet wearing riders, and I think that their net benefit is negligible.
Very fair point on ‘the weaker the helmet…’, except one assumes most helmets being worn have passed the relevant safety standards, and so from that standpoint most destructive hits have had some fair degree of force behind them.
I have to disagree with you on the brain damage issue, because it is the rate of acceleration (negative or positive) that is of prime importance in that instance, and if you consider under the same impact loading, if a head hits the ground unprotected there is say +/- 3mm of combined cushioning of skin and skull deformation at the point of impact and for arguments sake lets say that results in a 150g deceleration, if there is under the same scenario a combined cushioning of 12mm resulting from polystyrene deformation (whether or not it ruptures) then that drops the deceleration to under 40g, which is orders of magnitude less dangerous for the brain.
I think, possibly contrary to many on this forum, that for your average around town cyclist helmets do little to improve their safety and would agree with you on your limited net benefit. For chidren with their combined poorer judgement and more susceptible brains etc, I suspect they provide quite some benefit, even in the accumulated non-destructive knocks which (a la rugby, boxing et al) can aggregate brain damage. For me as a racer who, when I hit I tend to hit with some force, I think they can be a ‘life saver’. I am fairly sure that compulsory helmet wearing has a negative health effect on the total population but makes negligible difference to the individual cyclist. I’m fairly certain that individual choice to wear a helmet in quite a number of cases helps prevent major injuries and on that basis confers a helath or safety advantage to the individual cyclist.
morgoth985
Definitely. The slower I go,
Definitely. The slower I go, the more close passes, beeps and rants I get. Doesn’t even matter if the reason I am going slower is that I am with the kids.
[/quote]This last. Although slightly off topic, I simply cannot believe (well actually I can, but that’s even worse) that grown adult males are prepared to shout foul mouthed abuse at children.
Podc
PRSboy wrote:hawkinspeter wrote:Combined with the data that shows drivers give less space to helmet wearing riders, and I think that their net benefit is negligible.Interesting one that…
I am also convinced that drivers seem more patient/safe around me when I am giving it some welly rather than pottering about on the tops. Anyone else noticed this, or the opposite?
PRSboy wrote:
Shrewsbury PSCOs committed a similar faux pas on twitter last week:
No but the research on helmeted vs bare-headed riders is real. For best results grow your hair long (or wear a wig) and wobble a bit.A cycle helmet and shatterproof sunglasses are a must for anyone on their bike this sunny Bank Holiday Monday. Quite a few more mature males seen without. Experience counts for nothing when you hit a pothole. #SafeCycling #WearAHelmethttps://twitter.com/ShrewsburyCops/status/993524733189738496%5B/quote%5D
I’d like to think that they actually read some of the informative responses.
PRSboy wrote:[quote=hawkinspeter]Combined with the data that shows drivers give less space to helmet wearing riders, and I think that their net benefit is negligible.
madcarew wrote:hawkinspeter wrote:madcarew wrote:hawkinspeter wrote:wknight wrote:The one key statistic we are missing is how many people saved a trip to The hospital or even calling an ambulance because the helmet saved them.I witnessed two crashes very recently where the person walked away, but their helmet was a complete shattered mess. That would have been their head and yes it is personal choice, but no one complains about wearing a seat belt. Please don’t say there is data, because the data we need re Helmets has not been gathered. Go visit a&e and see head injuries.
If the police get involved why not, remember it’s them who have all the paperwork, investigation and having to give the family the bad news
If a bike helmet is a “complete shattered mess”, it means that the energy involved was much greater than the helmet was designed to protect against. The main protection from a bike helmet comes from compressing the expanded polystyrene inside it, not from the thin plastic outer that holds it together, so if the helmet shatters, it means it’s not doing its job correctly and most likely provided only very minimal protection.
Real life impacts are very complicated actions, and it’s entirely possible that the inital ‘killing’ impact deformed the helmet and protected the wearer, but also ruined the integrity of the helmet such that subsequent smaller impacts destroyed the now substantially weakened helmet, but those impacts were not capable of doing serious damage to the encased skull. So, a destroyed helmet does not mean either that it was subject to impacts outside it’s design envelope, nor that it offered skant protection. Just because an air bag is a torn bloody, muddy floppy mess and the vehicle didn’t stop when it deployed doesn’t mean that the air bag offered no protection at the time of impact.
I get your point, but does that mean you support the opposite view, that if a helmet is destroyed it means that it provided a high level of protection? That’s what I was arguing against.
If a helmet is destroyed, as I pointed out, it may have provided a high level of protection, but for sure there will be instances where the helmet provided negligible protection and was destroyed. I think these may be the minority of cases where the rider survived though. To me it’s hard to envisage an impact destructive enough to destroy a helmet that wouldn’t have had fairly devastating effects on the head contained within had it not been there, which is really what saying ‘it provided negligible protection’ means
The site linked through http://road.cc/content/feature/241993-when-should-i-replace-my-bike-helmet – https://helmets.org/ – seems to reckon that you should replace a bike helmet when there’s pretty much the slightest scratch/dent/fading. The helmet currently sitting on top of my wardrobe at home has lots of scratches, all of which are from poorly trimmed shrubbery on my local cycle route, none from actual falling off or collisions… Does this mean that the helmet is now ready to go to landfill?
PRSboy
madcarew wrote:hawkinspeter wrote:madcarew wrote:hawkinspeter wrote:madcarew wrote:hawkinspeter wrote:madcarew wrote:hawkinspeter wrote:wknight wrote:The one key statistic we are missing is how many people saved a trip to The hospital or even calling an ambulance because the helmet saved them.I witnessed two crashes very recently where the person walked away, but their helmet was a complete shattered mess. That would have been their head and yes it is personal choice, but no one complains about wearing a seat belt. Please don’t say there is data, because the data we need re Helmets has not been gathered. Go visit a&e and see head injuries.
I’m not convinced as the general design of bike helmets has very clear structural weaknesses (or vents as they are often called) and any non-flat object hitting a helmet has a reasonable chance of destroying it. Your argument that a destroyed helmet most likely provided significant protection is begging the question.
I don’t think any of it is as absolute as your alterrnative proposition “the opposite view, that if a helmet is destroyed it means that it provided a high level of protection?”. And at this point we get to semantics, because I’m uncomfortable with “most likely” but comfortable with “fairly likely”. I take your point about the vents and a non-flat surface (eg rock or top of fence post) but what would the effect on the skull be in the absence of the helmet. I think it’s going to be generally unlikely that in the event a helmet is destroyed (I was envisaging the majority of the helmet being in pieces) that an unprotected skull in the same instance wouldn’t have benefitted from a helmet between it and the striking surface.
I think we need some experimenters to figure out the real value of destroyed helmets.
I just object to the naive view that a destroyed helmet must have provided significant protection, when I would expect the opposite to be more likely.
Well, I nominate Donald Trump as crash test dummy #1
I don’t think the opposite is more likely, and just because it’s a naiive view doesn’t mean it’s wrong 🙂
Really, to my mind, the crux of that argument is given that a head was encased in the helmet at time of destruction, and significant force is likely to have been applied to destroy it, what would have been the state of the head had the helmet not been there. Generally speaking I think the answer has to be “worse”, probably normally coupled with “considerably”. 🙂
madcarew
madcarew
