- This topic has 5 replies, 3 voices, and was last updated 8 years, 6 months ago by .
Hi all,
My DT Swiss (R32 Spline DB) wheels have developed a bit of play in the rear wheel. The rim is able to rock about 1mm to either side, the movement is probably only 0.25mm either side at the hub.
What could cause this and are there any suggested fixes (I think a trip to the LBS may be in order!).
I’ve made sure the thru axle is correctly done up and that the dropout is tight – the play isnt bad enough to make the disc rotor isn’t rubbing on the pads.
Cheers.
