- This topic has 24 replies, 15 voices, and was last updated 8 years, 7 months ago by
peted76.
April 13, 2018 at 2:13 pm #28369
Johnnyvee
Hi everyone thought I’d throw this out there.
Since joining a club before Christmas I’ve gotten a bit fired up and am riding longer and slightly quicker. I’m using my Jamis Renegade Elite with my hand built wheels and it’s certainly quick enough on the club runs. However I’d like to get a new summer bike but am getting increasingly confused by what type.
I will be doing quite an amount of test riding where I can as I don’t like buying blind.
For the average club rider would you say lighter is better than aero or as I suspect I’ll be happier on whatever I feel more comfortable on? Was riding mostly up to 17mph but the speed has just started to nudge up abovev 17 though not over long distances yet.
Or is having more than one bike a luxury I really don’t need?
I’d be looking to drop around £2k and it would have to have discs and I don’t mind last year’s models.
I’m trying one of my riding buddies rivet rider in the next couple of weeks – that’ll be interesting.
Cheers
JV
peted76
I think this thread peaked
I think this thread peaked early on and is now well and truely in the decline..
You’re enjoying bike riding and are getting fitter and faster. Buy a new bike, it is the answer. Yes you can buy more speed by upgrading your current bike parts, but at the end of the day, you’ll be left with a bike which will bug you. Buy that new bike.. it’s part of your initiation to the quirly world of cyclists who’ll tell you not to buy a new bike (however have probably brought a gazillion new bikes in their past)… Buy the bike and get the new bike feeling.. quick before summer gets here!
I believe for your budget, if you looked at a new bike you should upgrade to a road race bike, it seems the kind of riding you’re looking to achieve is racy, so although you’re doing well on a more upright bigger clearance sort of bike now, any ‘normal’ road bike will show you ‘some’ advantage over the Jamis you’re on now. For your budget you should consider Aluminium framed bike, which nowadays will be far better than any entry level carbon frame…. the Cannondale CAAD12 Ultegra Disc is about £2k, I bet you could source last years for under £2k, you’ll not get much better bike and spec for your requirements than that (you should be able to get 10% off ‘any’ new bike anyway in an LBS or decent shop which would bring it down to less than £2k).
I also see a cannondale synapse ultegra with discs for about £2k, this is not the same as ther caad12 which has a far nicer crankset and acessories, don’t be fooled by the carbon factor.
Canyon48
fukawitribe wrote:BehindTheBikesheds wrote:Also going for discs is another 8-10 watts or so ‘lost’.He’s already got discs on the bike so tricky to avoid. Also for a fixed speed and yaw angle, could be 8-10 watts, could be 10-12, could be 1-2, could be less, we just don’t know on this set-up – there’s no general “discs cost X watts” factor to apply.
^Ditto.
Disc brakes actually lose very little, if anything, when compared with rim brakes.
In fact, disc brakes often outperform rim brakes at positive yaw angles because they are sheltered from the incident airflow.
fukawitribe
simonmb
Do a bike fit, learn (and
Do a bike fit, learn (and practice) which are the best aero positions to ride in efficiently (and comfortably), get some 40mm+ aero wheels (spend big), lose more weight.
That Jamis looks good – and by swapping the wheels back to the originals you’ve got a great all-round solution.
Happy riding 🙂
don simon fbpe
The differences are going to
The differences are going to be minimal, unless you are particularly anal, especially on a £2k bike. You’re always going to ride a bike that you’re comfortable with and less likely to ride a bike that you don’t get on with. It’s not like you have the paycheque incentive.
Rich_cb
BehindTheBikesheds wrote:Chris Boardman says that aero has an impact even at low speeds, even going sloly uphill, he repeated this this morning when commentating on the ladies road race in the commonwealth games.
Aerodynamic benefits of bike and body are by far the biggest factor in terms of effort expended, the body is roughly 80% of all the resistance.
people are very willing to put up with a less than perfect comfortable body position to gain extra speed.
Your advice to forget aero is well off, it should be something first on the list, the bike the OP has is more of an endurance bike so more upright, a subtle change in body position, arms and clothing not to mention a more aero frame and wheels will ‘buy’ you less effort for same speed all things being equal.
Instead of dropping £2k on a bike maybe look at:
Lowering the stem/changing body position/getting some well fitted clothing, are you in the drops/on the hoods/on the top of the bars.
Think about how and when you raise your head, when you sit up/open your body as this changes your aerodynamic profile.
Think about shoe/pedal interface are your shoes reasonably stiff
Think about tyres and tyre pressures, could your tyres be swapped for a lower rolling type, how often do you clean your drivetrain.
Think about cadence, a faster cadence is more efficient than a slower one for most people.
Also, can you lose some body fat, how is your food before and during the ride, can this be improved so your perform better, even warming up before a ride can have an impact.
Once you’ve checked things you can do without buying a new bike and checked to see if this has made a difference then go spend your money, even if you don’t ‘need’ a bike, a new bike can often have a placebo effect even if the reality is that the aero and weight difference is negligible.
You didn’t actually read my comment did you?
Rich_cb wrote:
Rich_cb wrote:I think that most claimed aero benefits for bikes/wheels etc only really kick in above 40kph (25 mph). If you’re not likely to be hitting those sort of speeds on the flat then in reality the aero benefits for frames/wheels etc will be much lower. My advice would be to forget aero/weight and go for comfort. Get a good bike fit and then find a bike that matches your suggested geometry as closely as possible. If you’re on a well fitted comfortable bike you’ll be able to maintain a more aero position for much longer giving you far more of a speed advantage than any aero bike or wheel. As an aside it’s also worth looking at your tyres, when I switched from a fairly basic set of panaracers to some schwalbe pro ones I was amazed at the difference in speed.Chris Boardman says that aero has an impact even at low speeds, even going sloly uphill, he repeated this this morning when commentating on the ladies road race in the commonwealth games.
Canyon48
ChrisB200SX wrote:A new bike is always nice but you don’t need any more than an aero pair of wheels, tyres, maybe an aero handlebar, save a few watts. Although the recommendation of upgrading components isn’t a bad idea.Ditto the wheels and components.
For £2k you could get;
- DT Swiss PRC 1400 SPLINE 35 wheelset (1434g),
- 105 R7000 hydro groupset (weight saving there – and better shifting),
- Deda Superzero aero bars and stem.
You’d easily make £200-£300 back by selling the 105 5800 and TRP HYRD brakes (it’d be worth keeping the wheels spare)
ChrisB200SX
Looks like a decent bike.
Aero helmet and clothing could also save you watts. These elements are all to optimise your potential.
The rider is most of the drag, that’s the cheapest and simplest way to gain speed, without meaning to sound rude, you probably have good potential for improvement here.
Improving the rider is about maximising your potential. Changing what the rider wears or rides is generally just tinkering around the edges, unless you’re riding a Brompton… in a suit. Hope that makes sense?
While a lot of the advice in
While a lot of the advice in this week’s CW aero edition is good, I’d be careful of big numbers like the 22%, they don’t necessarily translate to that in the real world.
in which case I’d suggest that the CAAD 12 is similar enough to the Super Six to be surely worth a look.madcarew wrote:And +1 on the Cannondale Super six….
Buyers are spoilt for choice. For some more suggestions look at road.cc’s own 2017 buyer’s guide for bikes in the £1500-£2000 bracket at road.cc/207770
But in the end it’s personal preference and I’d strongly recommend that the OP visits a few shops and tries to narrow it down.
AfterPeak
I watched this a few days ago
I watched this a few days ago. Really interesting to see how super bike vs mid bike. If its real then basically unless you are a pro it won’t make a difference once you break the £1000k mark.Canyon48
Johnnyvee wrote:Sadly no I have the Renegade Expert 2016 version with some wheels made up on pacenti forza rims and tubeless tyres 32mm. It’s around 10kg at the moment and I weight around 96kg at the moment which is a good 8kg than when I started riding it. It was in the sale and already has shamans hydro disks which were a mid season upgrade…I am trying to get more aero and reduce the 80% of me but was wondering whether a dedicated Road bike would help or whether my gravel bike is as good as.
This is what I have – hope I’ve pasted the link correctly.
I appreciate it’s the engine that matters and a good few people are a fair bit faster – even on Bromptons…
Ah ok, you certainly have a nice bike in that Jamis Renegade Expert anyway.
The difference between a “gravel” bike and an endurance is surprisingly small, largely the differences are in the tyre clearance and gearing. A dedicated road bike will have slightly steeper tube angles and be a little more responsive, but it will lose the ability to take wider (32+) tyres.
I have a Whyte Wessex as my commuter bike, it’s got more relaxed geometry compared to my Canyon CF SLX Disc road bike and it weighs about 9.2kg (which is a good 2kg over my Canyon). You’ll struggle to find many disc brake bikes less than 9.2kg for less than £2500.
I’d certainly consider upgrading to 105 R7000 or Ultegra R8000 and buying a set of lightweight mid section wheels – like DT Swiss ER 1600 Spline DB (1528g). Only reason I say this is because you might find that if you spend £2k on a new bike, you’ll end up with a nice carbon frame with 105 and RS505 disc brakes – the wheels won’t be anything fancy and it’s unlikely to weigh much/any less than 9.5kg.
Both the Whyte Wessex and the Trek Domane SL5 disc are good, but they are both a bit over £2k.
Johnnyvee
Dnnnnnn
Sensible advice above about
Sensible advice above about where the aero gains are to be made – on the bit representing 80%+ of the drag (I.e. you).Canyon48
Aero is faster, even at
Aero is faster, even at speeds of only around 17mph. That said, don’t base your decision solely on which bike is theoretically faster.
Wheels are far more influential than an aero frame – again though, these figures shown here are for a very specific condition – https://bit.ly/2vabTMw
At 2k, I would recommend sacrificing “aero” for superior components. Most aero bikes around the 2k mark have shallow “training” wheels on them to save money, and often they’ll mix groupsets (lower spec components).
Getting your body “aero” is far more important than getting an aero bike. If you (for example) don’t have good flexibility (so can’t get long and low) and weigh a fair bit, then riding an aero bike may not be suitable/comfortable.
I think I should also add that the Jamis Renegade Elite is a very good bike (I’m assuming you have this one http://road.cc/content/review/152497-jamis-renegade-elite) for £2k, you won’t get anything much better. I would consider upgrading to Ultegra R8020 (hydro or R8070 (hydro Di2). And/or getting some aero hoops (Hunt or DT Swiss).
Glad to hear you are getting more into cycling, always great to see more people involved :D!!
