- This topic has 0 replies, 1 voice, and was last updated 8 years, 7 months ago by .
Hi,
I need two informations about Boardman Team Carbon (best will be 2016) but with upgraded crank to Shimano 105 5800.
Which support did you use? Will Rotor suport Race PF4624 68mm be ok and better than adapter to BSA and BSA BB?
And second what space in mm have you got between left arm of the 5800 crank and the frame? I want to install there stages-like power meter and manufacturer says that 9mm allen key should fit there.
Best regards
