- This topic has 12 replies, 10 voices, and was last updated 8 years, 6 months ago by .
Hi all,
Just seeking some advice on bike frame sizing ahead of a new bike purchase.
To give you some background, my stats are as follows: height 184cm, inseam 92cm, arm span 188cm.
I’ve been riding a 2014 Giant Defy 1 (M/L) over the last 4 years. Despite several bike fits with a very reputable local fitter, the bike has never fit me brilliantly. Several changes have been made to make it more comfortable for me, which have helped, but it’s far from perfect. (I should really have done more research on the geometry before I purchased it, however, it was my first road bike and I’ve learnt my lesson, hence doing some thorough research now before purchasing a new bike!).
As can be seen from above, I have long legs for my height. I currently ride with a saddle height of 810mm and despite shortening of the stem by 30mm during a fit last year, I’m still struggling with reach and feel very stretched out to the front of the bike. Riding on the hoods is uncomfortable and not sustainable for any length of time and I tend to spend most of my time riding with my hands on the corners between the tops and hoods. I feel excessive pressure through my hands (like I’ve got someone sitting on my shoulders!) and as a result tend to get numbness in the hands and although spending more time on the drops is easier on the arms, I then suffer from pressure on the soft tissue “downstairs”. I have purchased a new saddle (Fabric Line race saddle), in the hope that that will help with the soft tissue issue. While I endeavour to keep a soft bend in my elbows, I subconsciously want to lock my arms out to take some of the strain off the muscles.
Essentially, I’m looking for some advice on where I should direct my search in terms of brands / models of bike with a geometry that will suit me better? I.e. shorter top tube?
My Giant Defy has a top tube length of 560mm and while this isn’t huge, it seems to be a touch longer than most equivalent lengths on similar sized frames. I’ve looked at the Canyon Ultimate – I’d like to go with a small to get the benefit of a top tube that’s 17mm shorter, but then I’m limited by the max. saddle height of 790mm. So instead do I go medium to get the required saddle height and shorten the stem? (as the top tube on the medium is only 4mm shorter than my Defy). If so, how much can I shorten it by before the handling starts to suffer?
Would appreciate any thoughts – thanks in advance.
