- This topic has 9 replies, 8 voices, and was last updated 8 years, 7 months ago by .
Hi all
I’m trying to get a 35mm tubeless tire (Compass Bon Jon Pass) mounted on a FLO wheel. I have an AirShot2 (http://www.airshotltd.com/product/airshot-2/ – great product BTW), with which I can get the tire to pop onto the rim, but only if I remove the valve core (which is what I have done in the past with other tires). My problem is that when I disconnect the AirShot and the air comes out, the tire pops back off the rim and can no longer be inflated with a track pump when I put the valve core back in.
In order to get the tire to pop on I had to lubricate its wall and the rim so they’d seal more rapidly/well. I first did this with some washing up liquid and later thought that might be part of the reason the tire pops back off the rim when I deflate. But the same happens when I use just a bit of water.
So I’m a bit stuck. Has anyone been in this situation before? My next step will probably be to take off the tire, clean everything, and try again. I’m a bit reluctant to do that though as I already have sealant in the tire and would prefer it if things Just Worked. I’ve had a couple of tubeless tires on this wheel before but not run into this (or any other) problem in getting them mounted.
Thanks for any thoughts / tips!
