- This topic has 13 replies, 8 voices, and was last updated 8 years, 7 months ago by
Roadie_john.
March 21, 2018 at 8:00 am #28271
Chay
Hi
Could i fit 28mm conti gp4000s on mavic ksyruim rims???Anyone tried.
I don’t want to waste my money and order some just to experiment.
Ta
Roadie_john
BehindTheBikesheds wrote:I run a 28mm on a 13mm rim (Mavic Open4Ceramic), in fact I’ve run a 32mm it and was fully loaded. It might look odd/bulbous but the reality is I haven’t experienced any squirm when going into tight corners at speed.I still use my 2001 Mavic SSCs, they’ll cope with 32s no sweat, it’s always the frame that is the limiting factor.
Have fun.
This.
I have run everything from 19mm to 28mm on 13mm internal mavic rims no bother – routinely road racing 25s on quite tight crit cuircuits for a while. Friends who race cross routinely use 28-35mm cross tyres on MA2s and Open pros at 13mm internal diameter.
It might be a bit less aero (arguable), and looks a bit odd, but never felt dodgy in corners.
The frame (or brake caliper arms) is the issue.
Roadie_john
Have fun.
This.
Roadie_john
Have fun.
This.
Have fun.
Chay
Yes, I agree. 28 are
Yes, I agree. 28 are comfortable fit. 30mm depending on brand would be fine.I have some pacenti rims that I may try with the 28mm tyres, these always add lots of width to a tyre.
700c
4 days late to this but i run
4 days late to this but i run this exact model in winter (v2) and can easily get 28mm vittoria corsas on Zondas. I reckon you can even fit a nominal 30mm front and rear without mudguards.( I also run trp long drops – lovely brakes).I find the width they blow up to is a moot point; obviously you want a wide rim for 28+ but the greater the stated size the more material, volume and height you get. Height being the limiting factor on this bike for fit.
Chay
So. 28mm will fit on the rear
So. 28mm will fit on the rear. But I only had one larger inner tube so couldn’t try the front.My combo doesn’t add much width but added some height.(the 25mm did measure up quite large).
Cheers for the help
Stratman
Don’t know quite what the
Don’t know quite what the difference in clearance is, but I’ve 28mm GP4S on my gfti Disc with full guards
Chay
Hi.
Hi.I’ve order some and will post when I fit them. Fork looks fine it is the rear stay which look tight.
For info trp calipers
HLaB
Im not sure what version my
Im not sure what version my gf ti is (its circa 2012) but Kinesis say its Tracer forks are good for 28mm; I’m going to try at the weekend.
Chay
Yes rim and long drop but an
Yes rim and long drop but an older version.I’ll measure, I just know conti and come up large
kil0ran
Is that the one with rim
Is that the one with rim brakes and long drops? Kinesis say 30mm will fit
CXR94Di2
Get a rule, measure across
Get a rule, measure across chain/ seat stays and fork. If 30+mm or more good to go
I have Kinesis Tripster V2, I can fit 50mm tyres 😀
