- This topic has 7 replies, 5 voices, and was last updated 8 years, 8 months ago by .
Maybe someone with a workshop could use?
I noticed common 3.7 volt lithium batteries slide into the dropbar, hence they’ll also fit flatbars. Anyone manufacturing battery holders to suit? Furthermore handle bars of LED arrays? Hands might cover such during daylight rides while upright yet night riding I’m sure light obvious hence willingness to reduce holding patterns wouldn’t be a problem.
High intensity LEDs are bright as.
My clip on lean on bars are bridged handle. If I could find battery holders to fit tube I’ll be looking at drilling a light array central with a small triple throw switch to use 1 battery at a time. Even a drill straight through with a 10mm shaft big head multiple LED light array would bolt in secure and out of the way. Hollow shaft with internal wiring could bridge batteries to light array.
Cheap, easy, bright and relatively wind less.
I’m probably dreaming. Battery holders would be a start though. Maybe with switch on battery cap, simple circuit per battery?
