- This topic has 10 replies, 10 voices, and was last updated 8 years, 7 months ago by .
Following on from another thread – You can keep yer watts and yer weight – the only reason I run tubeless is to stop most punctures while out biking. That’s it.
I was out on sunday on some awful gritty muddy road and the front tyre went down to about perhaps 30psi. Tyre had punctured and the sealant did its job. I just pulled over, inflated with co2 and in 2 minutes was riding again.
Last spring I serviced the tyres – There were 7 thorns in the tyres that the sealant sorted out. That’s 7 roadside punctures avoided in the cold winter months (yes I do go on some pretty shitty roads).
I carry a spare tube in my seat tube, co2, those wriggly worm things, a pump and a tyre boot. Plus all the other shnizzle for general maintenance, so I’m defo not a weight weenie!
Is tubeless setting up a pain in the arse? Yes it is. Is it worth it? definitely.
Just my tuppence worth 🙂
