- This topic has 4 replies, 4 voices, and was last updated 8 years, 5 months ago by .
Hi,
I’m using some Mavik Aksium’s as winter wheels at the moment. Noticed recently that the wheel isn’t true in the frame, ie it’s closer to the drive side chainstay then the non-drive side. Other wheels are centred and I think it’s happened since I started using the wheels. Frame is a Supersix Evo MK1 so the chainstay clearance isn’t huge and the tire (23mm) is fairly close to the stay.
I wanted to ask if it’s possible to adjust the wheel to center it in the frame?
