Fixed gear
  • #28128
    Boatsie
    Anyone know of 130mm track hubs with chainline 50mm from centre please?
    Sorta need one. Preferably 32 hole.
  • #912237
    Roadie_john
    Any track hubs will fit 130-
    Any track hubs will fit 130- you just need two 5mm spacers or 10mm worth of M10 washers… of the chain line is wrong, get a wheel builder to re/dish the wheel. Usually chainring on inner side of a double chain set works out fine…
    #912235
    Boatsie
    Thank you, I didn’t think to
    Thank you, I didn’t think to move chainwheel inwards. Arms are in, I guess I could space chainwheel yet already having about 3-5mm spacing I am skeptical.
    I think it is just as easy yet cheaper to buy whole bike.
    Any suggestions? All I can think of is a high bottom bracket. I had ordered 1 but they took my money and a month and then I read that money was refunded yet bank doesn’t agree.
    The donor bike still perfect as a hub drive yet I wouldn’t recommend to anyone to fix a 130mm axle slot. I’m finding the rule of 3 working well.
    Cheap, quick, quality. Pick 2.
    Sitting on this one a few seasons hoping cheap and quality become of this.
    Thanks regarding crank info.. That might work.
    #912233
    CXR94Di2
    https://www.sjscycles.co.uk
    https://www.sjscycles.co.uk/hubs-fixed-track/?width=130
    surly mention 47.5mm chainline
    https://surlybikes.com/info_hole/faqs/what_chainlines_do_your_hubs_provide_and_are_they_all_the_same_hub_shell_sp
    you could see if different spacers are available or have some made
    it would be easier to add remove spacers on the crankset bottom bracket if it’s a threaded version to get desired chainline
