- This topic has 3 replies, 3 voices, and was last updated 8 years, 8 months ago by .
Do lower pressures change the available tyre clearance for a given frame? For example, if a frame will take a 25mm tubed tyre at 100psi, could you potentially get away with a wider tyre at a lower pressure? Say a 27/28mm at 70psi?
Or is rim profile more important in determining actual vs nominal tyre width/height?
