- This topic has 6 replies, 5 voices, and was last updated 8 years, 10 months ago by .
I changed crank arms.
Square drive Shimano bottom bracket.
Using the crank arm remover that comes with the small bicycle tool box, I noticed the pushing bolt pushs onto the bottom bracket outer threads. I didn’t like that! Having grown around tools and their functions, threads are important!
The donor bike arms were then removed. I used a small chunk of metal to broaden the push onto the boarder between the thread and the square perimeter. Worked perfect on the 1St arm yet failed and compressed into the thread on the last arm. Ruined it unless tapable. 😉 ruined it.Does someone know of a non thread touching crank arm remover used with Shimano square drive cranks please?
My thoughts at the moment are to grease the tools thread, weld a washer of less diameter than the square length and be happy with a non serviceable tool. I figure that should be okay as tool use is not often; nearing rare.A further question I have is chain wheel. Having replaced 3 to a 2, assembled yet loose and awaiting greese and tightening. I was thinking of assembling with old cassette, very worn chain and worn chainwheels to replace after running in assembly and different shifters. Do I need remove crank arm to switch the chain wheels?
🙂 should have bought a new one. Argh
