- This topic has 13 replies, 6 voices, and was last updated 8 years, 9 months ago by
Langsam.
January 24, 2018 at 12:31 pm #28068
Bikeworkhorse
I know there are plenty of reviews for these lights but before I spend this sort of money, I wondered if anyone with experience of them could point me in the right direction.
I commute 17 miles through mostly grotty muddy lanes. I have an exposure joystick which is just about ok if the road is dry, but in the wet on the darker roads it’s useless… and sometimes I forget to charge it.
So, I’ve found a good deal on an SP dynamo hub but can’t decide on a front light.
As far as I can tell, lights designed for off road send the beam out in all directions so whilst they often have a high output, lots of it is lost in directions that aren’t any use for the road and will dazzle oncoming traffic. But the Supernova E3 triple has such a high output, 800 lumens, even though it’s designed for off road, it sounds like it will light up the lanes like a floodlight…and there are some good deals on ebay.
For road lights, the Supernova E3 pro 2 and Edelux 2 seem to be the most recommended. But will they be significantly brighter than the Exposure joystick on the bike at the moment?
So what’s it to be, efficient road specific lights or crazily bright off road lights?
Langsam
I use a cheap 35 Lux front
I use a cheap 35 Lux front light and a basic Standlicht rear light.
€20 inc. postage on eBay.de, the item number is 171547551163 for something similar.
i wouldn’t disregard a cheaper option. Even bottom of the range LED lights are fine for commuting, in my experience (YMMV).
kil0ran
Bikeworkhorse wrote:kil0ran wrote:
Just give thought to whether you need the daylight running lights and light sensor. There’s only about £20 difference between the two versions of the light, but that would buy you a rear light. On pitch black lanes you’ll need to put it on The rather than Senso to switch off the DRLs and put full power to the main beam. I do use mine on the morning commute in Senso mode but to be honest you could just run the full lamp output instead. When you buy the light it comes with everything you need to connect it to the hub and a rear light except the plug (which should come with the hub). No soldering or patching required, all you need is an Allen key to remove your brake caliperBikeworkhorse wrote:Thanks. That’s just the information I wanted. It’s so much better to hear from people who have used the product in real life than a review.
The Busch & Muller Cyo IQ Premium T Senso Plus Headlight sounds like a good option at that price.
I like the idea of the daylight running lights…maybe a bit less drag from the hub. Found the prices from Germany are much less than here:
https://www.bike24.com/1.php?content=8;product=67804;menu=1400,1410,1411;mid%5B39%5D=1;orderby=3
Thanks again…and it’s good to know there are others out there battling with the cold, rain, wind, ice and mud every morning.
Definitely buy from Germany – I got mine from Rose. They’ve usually got awesome deals on dyno wheelsets too, or take a look at Taylor wheels on eBay. Usually built with Shimano dynohubs rather than SP though. You can’t ride a bike after dark without dyno lights in Germany so market volumes are much higher and therefore prices much more competitive.
kil0ran
daccordimark wrote:kil0ran wrote:daccordimark wrote:I’ve got the snappily named “Lumotec IQ2 Luxos U senso plus front” light from B&M and I have to say I’m slightly disappointed with the light output. The beam is broken up with shadows rather than being an even spread which is nothing like what you see on Peter White’s site linked above. Also, I find that even using the 90 lux flood mode it isn’t bright enough on unlit country lanes above 25mph to highlight the potholes and surface changes soon enough especially when it’s wet. I supplement it with a 600 lumen Lezyne for the unlit bits of my commute.Having said that I do appreciate the wide flat-topped beam and for general riding it’s much better than the more concentrated beam of the Lezyne.
Mark.
I was put off the U range for just this reason, the beam shape is better on the Cyos, despite those lights having lower output. Similar ergonomic issues with the IQ-X – I guess the market demands extra features but the product designers at B+M have lost their way a little.
I guess I’m more risk-averse than you, I wouldn’t ride at 25mph+ on unlit country lanes round here, too much capacity for critters to appear out of nowhere. In daylight I’ve had near misses with pheasants, squirrels, and rabbits recently so perhaps I’m being conditioned into being over-cautious.
Shame I didn’t pick up on that difference between the U and non-U lights when I did my research but I do like the neat all-in-one charging setup of mine. I know what you mean about the speed on unlit roads and to be honest I only have two short sections of downhill where I’m going that fast on my commute.
I run a B+M rack mounted rear dynamo light as well which might reduce the output a bit I guess. That’s another slight disappointment because I bought the one with the built-in brake light function but it doesn’t seem to work. That might be because it is wired to the tags on the front light rather than direct to the dynamo but I haven’t experimented with splicing the dynamo output yet.
Despite my moaning I’m glad I switched to a dynamo system – it’s always available, provides plenty of good quality light in most conditions and in my case means I can charge my mobile phone when I’m “off-grid” touring.
Mark.
I thought I read somewhere that the U isn’t compatible with the brake light function on the rear but I might be wrong. I think its because the light is actually powered from a cache battery rather than direct so the rear light won’t be able to detect the voltage drop as your hub speed drops. The U needs the cache battery so it can provide a reliable supply to any accessories you’re running from the charging port.
You’ve definitely got it cabled up right – my rear light is done the same way using the tabs on the Cyo and it definitely works OK.
Running a rear definitely reduces front light output on my Cyo – I notice it particularly as I do the same route on both bikes with the same model light but only one has a dynamo rear.
OP – all the above probably sounds horrendously complex but modern dynamo lights really aren’t compared to the older style ones which earthed via the frame. The B+M really is plug and play, admittedly with tiny connectors that you need to be careful with. Just make sure you tape the connectors for the rear light if you’re not using one.
daccordimark
Mark.
Mark.
Bikeworkhorse
John_S wrote:Hi Bikeworkhorse,Like you I got fed up with battery lights and having to always think about charging etc.
I made the switch to a dynamo set up for my bike which is used for daily all year round commuting and it’s one the best decisions cycling wise that I’ve ever made. I absolutely love having a dynamo hub & lights and touch wood it’s been fit & forget for me so far and now I just have instant light there whenever I set of on my commute.
Admitadly this is my first ever dynamo set up and so I have absolutely no frame of reference to compare it against however I’m personally very happy with it.
Firstly my commute is roughly 15 miles each way and the majority of it is on unlit rural roads which are rough, dirty and unlit. Then after the rural bit it’s urban lit roads for the last bit of my commute.
My set up is a Shimano dynamo hub with a B+M IQ-X and and B+M rear dynamo light. Like I said this is my first ever dynamo light and so I’ve got no others to compare it against but I’ve been happy with it and I think that the cut off beam at the top is a very sensible thing to have in order to not dazzle or annoy other road users.
Good luck with your search and figuring out the right lights for you. Whichever ones yo go for I hope that you enjoy the switch from charging battery lights to using a dynamo set up as much as I have because I’d definitely recommend it for anyone who commutes all year around.
John
Hi John, I’m looking forward to making the switch. I’ve stopped wishing for the lighter mornings of Spring (nearly) so I can try these lights! My commute is mostly lanes with some fairly out of the way bits past lots of mucky farms. Pot holes everywhere after the snow and ice.
Thanks for your help.
Bikeworkhorse
kil0ran
When you buy the light it comes with everything you need to connect it to the hub and a rear light except the plug (which should come with the hub). No soldering or patching required, all you need is an Allen key to remove your brake caliperJohn_S
Hi Bikeworkhorse,
Hi Bikeworkhorse,
John
Bikeworkhorse
kil0ran
Mark.
daccordimark
Mark.
kil0ran
I ride a similar distance way
I ride a similar distance way after dark (leave work at 6pm) on completely unlit roads with plenty of (mostly furry) hazards.
The biggest benefit of a dyno light is positioning because mounted at the fork crown you get good shadowing of potholes and the like.
I used to use the Exposure Revo dyno light (essentially a downpowered version of their main line of off-road lights) with their hub which is a rebadged SP. It was brighter but not suited to fork crown mounting and didn’t have the beam shaping of the German lights. Its also quite a lump compared to the lightweight B&M lights I use now.
I’ve now got a B+M Cyo Premium Senso T (https://www.sjscycles.co.uk/lighting/busch-muller-cyo-iq-premium-t-senso-plus-headlight-for-hub-dynamos/) on my commuter and the non-Senso version on another bike and they both do the job very well indeed. I looked at the other options from Son, Supernova, and B+M and these were by far the best in terms of price/features/performance/weight. The ones you mention are solidly built but no brighter than the B+M and heavier because of the heat sinks and metal housing they use. One of my Sensos is 5 winters old (3 of those Scottish) and whilst the casing looks battered it is utterly reliable and still as bright as the day it came out of the box.
If you go with fork mounting there are a couple of things to bear in mind:
1. Make sure that your cables aren’t fouling the back of the light – particularly an issue if you have headtube mounted cable stops
2. If you’re running mudguards or fat tyres don’t discount the amount of shading you’ll get from the tyre/guard
I had both of these issues and solved them with the Supernova Multimount which lets you set the height and angle of the light to clear cables and minimise the shading.
You don’t say whether you’re running calipers or discs? If you have discs and the fork crown isn’t drilled Supernova do a mount that will screw in to the bottom of the steerer – this can also be used with the B+M lights.
One final thing – don’t forget that if you intend to run a rear light that your main beam power will be slightly reduced. Possibly worthwhile sticking with a battery-powered rear if being able to see where you’re going is most important. One of my bikes has a B+M Line Plus rear light which is amazing (brightens as it detects braking) but there is noticeable reduction in output from the front light.
I’m perfectly able to hammer along at 20mph on country lanes with these lights, I’d never go back to batteries and bar-mounted lights when commuting. Mine are left on all the time as daylight running lights and when you’re commuting every day its quite satisfying not to have to remember to switch them on/charge them.
CXR94Di2
I have the IQ X from Busch
I have the IQ X from Busch Muller. Excellent output and beam cutoff. -
