- This topic has 15 replies, 14 voices, and was last updated 8 years, 11 months ago by
dottigirl.
December 28, 2017 at 5:56 pm #27956
itaa
Specially at the moment when it gets below 0 and is super windy, the wind just sucks the life out of me and I get ill almost everytime I have to ride or even walk in it, lately I just drive a car if I see the wind is crazy- sucks so bad 🙁
I wear wool socks, all merino baselayer (pants/shirt) + Cashmere jumper+ down windbreaker + Merino Buff as a balaclava +wool hat , I’m mostly wind-proof till the neck are, however the damn wind still blows in my face and completely f.cks me up, I saw someone today was wearing a large builder googles (almost like a ski-mask) ,looked weird but maybe it helped him? I don’t have any cycling glasses myself.
What do you do? What’s the secret?
dottigirl
In the coldest weather, I
In the coldest weather, I wear two merino snoods/buffs.
One is a much narrower tube and hugs my neck.
The other is wider, and I pull it up and double it over to cover the lower half of my face.
On my head is either a wide merino headband, or a merino beanie.
I’ve done up to -5 and been fine like that. Though, I will avoid ice.gmac101
Vaseline or Lip Salve. A
Vaseline or Lip Salve. A trick I learnt in Canada is to put vaseline or lip salve on the tip of your nose, along your cheek bones and on the tips of your ears – anywhere the wind catches. It provides a bit of insulation and keeps you warmer
Deeferdonk
Eat some pies. As a slightly
Eat some pies. As a slightly chubbier gent I seem to feel the cold a lot less than my skinnier mates.
Also perversely, statistically slightly overweight folks tend to live longer than people with the reccomended BMI.
http://www.independent.co.uk/life-style/health-and-families/features/why-being-overweight-means-you-live-longer-the-way-scientists-twist-the-facts-10158229.html%3famp
matthewn5
Old binder twine? Luxury.
Grahamd
mike the bike wrote:I was born in the forties so take a somewhat different perspective on foul weather. If it’s just below freezing I wear only an old sleeveless aertex vest and trust to my tattoos to keep me warm. If it’s well below zero and the wind is storm force or above I wrap my manly torso with two pages of Cycling Weekly, tied in place with string. The insulating properties of this august publication are known only to those who yearn for the return of the five-speed block, but trust me, you will need nothing more.
Surely you use some old binder twine not string?
mike the bike
asdfqwerty
I wear a merino neckwarmer
I wear a merino neckwarmer/buff, then I put on a cycling cap, then I pull the top of the buff up over my cap and put my helmet on over it. The buff basically surrounds my face at this point and traps a lot of heat against my head. Wearing the cap peak-down helps deflect a bit of wind as well.
Paired with a windproof jacket (Castelli Perfetto) and a good pair of overshoes, the only way I feel the wind is when it provides extra resistance to pedal against.
Sounds to me like you just
Sounds to me like you just need some clear glasses, cycling or otherwise. Currently I’m using some Uvex photochromic ones that go clear in low light conditions, but any kind should do the trick. I’ve sometimes used some cheap safety glasses – not stylish but they keep the wind (and dust/dirt) out of your eyes.
DoctorFish
itaa wrote:heh , but what about the wind dude?
Cold is nothing… The wind is the killer.
The wind doens’t make it through the clothing I mention above, so all is well. Can’t help you regarding cycling in to the wind and it being difficult, or being caught out by a strong side wind, but the clothing I wear keeps me very warm regardless of wind.
LastBoyScout
Sensodyne toothpaste and a
Sensodyne toothpaste and a mountain bike 🙂
itaa
DoctorFish wrote:I was out this morning, had to change my route several times due to black ice, so be careful out there. I was however plenty warm enough. Long sleeved base layer, normal short sleved jersey and then a stolen goat climb and conquer jacket. Stolen goat orkaan tights (also use dhb as mentioned above), merino socks, northwave boots, sealskin gloves, a head cover thing under the helmet, and a buff around my neck and lower face. A pair of glasses from optilabs which I use on every ride (very poor eyesite, so need glasses, but would wear glasses anyway as think they are the most critical items of safety kit on a ride). Only cold part really was around my eyeballs, and that was ok after the first 15 minutes when I started to warm up. Was out for about two and a half hours, but would have stayed warm all day if I had been out that long.I get scared by ice, but the kit I wear keeps me warm enough. I tend to stick to larger roads which have been salted, although any road is fine if it has been dry. Got caught out today down a country road, a runner comming the other way warned me that it was about to get very slippery, then there was a 4×4 pulling a van out of a hedge, so time to go back and try a different route down a major road instead.
DoctorFish
CXR94Di2
I stopped going outdoors in
I stopped going outdoors in Winter, 3 seasons ago. I use Trainer Road and Zwift to get my cycling fixLeviathan
Re Builder Goggles. Search
Re Builder Goggles. Search for Bolle Bandido. They are clear specs/goggles, get the chemistry lesson vibe. But you can get clear or low light orange. Decathlon do something similar. No frames, clear visibility, but keeps the wind and crud out of the eyes, paired with a good Gore balaclava or similar.
Canyon48
I don’t cycle at temperatures
I don’t cycle at temperatures below about 1 degree (having had a couple crashes on black ice).
I don’t go on rides over two hours if it’s really cold, instead, I do faster, harder, shorter rides.
For me, to keep warm, the following is enough; Castelli Difesa Cap, Crane (Aldi) cycling gloves, DHB merino baselayer, Madison fleece lined jacket, DHB Roubaix bib tights, Merino socks and Shimano RW5 shoes (though when it gets really cold I do need to cover the toes).
