The ultimate saddle bag
  • This topic has 40 replies, 21 voices, and was last updated 8 years ago by survivor.
  • #27916
    survivor
    Several close friends and I have been working on a bicycle saddle bag prototype and would like to get some inputs and feedbacks from fellow cyclists here. We want to make sure we are on the right path to help address the issues that current saddle bags have.
    As avid cyclists ourselves, we often time have our dilemmas when it comes to saddle bag. Practical or aesthetic? Size or storage? At one hand we want the saddle bag practicality of carrying around the essentials items like spare tubes and multitools during our rides. On the other hand we want to keep the clean aesthetic of our bike. In the case where the practical sense won the first dilemma, we typically still need to trade off between storage space or utterly bulky saddle bag. Even the ones least concern with aesthetic would shake their heads staring at the brick like saddle bag hanging below the bicycle saddle. Majority of the saddle bags in the market today are boxy and black, which doesn’t help to promote the saddle bag’s stylish or aesthetic aspect.
    What do you guys look for when choosing a saddle bag? What is in your wish list of the ultimate saddle bag? If you are not a saddle bag user today, what is holding you back and what will make you switch camp?
    Would you be interested if there is a saddle bag that can do the following?
    1. Compact enough to carry most of your essential items. Think 2 spare tubes, 2 tire levers,  2 CO2 canisters, Multitools with chain tool, patch kit, all these in a compact form factor.
    2. Stylish enough to not ruin your bike aesthetic, this can be quite subjective and personal but assume it meets your styling requirement.
    3. Quick attach and release. Much faster than dealing with Velcro.
    4. Abundant styling/color choices.
    We love to hear your inputs and hopefully we will be able to create something that all the cyclists want to use. Thanks!
Viewing 10 replies - 31 through 40 (of 40 total)
  • #907679
    survivor
    Dimensions for a snug racing bike type saddle bag should be circa 16cmx10x13cm LxDxW
    The dimension of the prototype that we are working for is more compact than 16cmx10cmx13cm LxDxW so hopefully it will be snug enough smiley
    #907677
    Velcro bags are not great but
    Velcro bags are not great but then bags with a QR system are more weighty and they need to be also carbon rail/oval carbon rail friendly which most aren’t and are an absolute bugger to fit properly.
    If I’m riding with my tubs I’ll take a Foam repair canister which acts to infate too, a mini tool and a couple other small bits (zip tie, latex glove, hand wipe), replace with 2xlevers , a single tube and instant patch when riding clinchers. My pump is clamped by its own holder at the bottle cage mounts..
    As the bag is not really load bearing something that could clamp onto the saddle rails like a pincer clamp and the bag attaches to the two clamps (Which are left in place) and a finger press release would work great. Or a rubberised strap that is attached at one side but also has a retaining peg, having multiple slots along the strap means you can keep the bag tight but also fit different parts of the bike securely and with scope for different sizings due to the elasticity of the strap and the slots for shortening/lengthening the reach of the strap.
    Also, does it need a zip?
    #907675
    survivor
    Thanks for the valuable
    Thanks for the valuable inputs!
    There is definitely no one size fits all for saddle bag storage. We think in general cyclists would want the saddle bag to be visually unobtrusive. So I guess the ultimate solution would be something compact enough to fit the absolute essentials yet have the capability to expand for more items if needed and still remains visually unobtrusive while in compact or expanded mode. And it needs to be compact enough to not rub the bibs.
    Looks like the ability to do quick release/attachment for bike swap is something important as well and we will definitely take that into consideration.
    #907673
    tugglesthegreat
    I went for the Evoc tour for
    I went for the Evoc tour for £15, will hold two 700c x 40 tubes and my tools.  It has internal mesh pockets on the sides and flap it has tarp material in the middle section for durability and for easy clean.  I generally use it for gravel events and it has been caked in mud and cleans well.  I guess you could argue that this adds weight!  Depends on your priorities.
    The fit is really secure and fast, and it is out of the way so no rubbing when peddling.
    #907671
    longassballs
    I don’t think there is a
    I don’t think there is a perfect saddlebag as it depends on the application and bike e.g. I carry different things between my 29er mtb and road bike, but assuming you’re talking road I really like my Castelli XL. They’ve embraced the black boxy look by making it a … black oblong. With no concessions to aero-ness it looks all the better. Fits two tubes, multitool, levers and a few odd ends. Don’t like CO2 which I would only use if racing, which I don’t, so the elastic strap under the bag for a pump suits me great. Although, I was stretching it a bit fitting in a medium sized Lezyne Pressure Drive that I subsequently lost after working itself loose that was my fault. The replacement size small fits great. So my perfect bag would have a secure fastening for a pump on the outside of the bag.
    If I raced I’d use a minimal saddle roll. If mtb a 29″ tube can be awkward to fit anywhere, never mind two. If on cx bike I can’t fit two tubes either, which I’d like to.
    I actually need a solution for my Mother’s bike. She rides a 29″ hardtail which in hindsight should have been 27.5″ as it’s too big for her and has very little seat tube showing. I got her a saddle roll so she’d have enough room to put on a rear light but the light isn’t very visible and she can’t fit a tube in the roll. Probably should get her a top tube bag. There are a hell of a lot of ‘casual’ cyclists who have little seatpost showing who need a dedicated tool bag elsewhere whereas these bags are marketed usually as food bags so don’t buy them
    #907669
    theRomfordRider
    I use the Thule Pack ‘n Pedal
    I use the Thule Pack ‘n Pedal Seat Bag in the winter as it hold way more than my summer bag and it’s water resistant too.
    I carry two tubes, two CO2, multi tool and two tyre levers, and if i pack it right sometimes my mini pump.
    https://www.thule.com/en-gb/gb/bike-accessories/panniers/thule-pack-n-pedal-seat-bag-_-pp_100013
    #907667
    andyp
    All I carry on a ride: Two
    All I carry on a ride: Two tubes, patches, multitool, cash. Plenty of options available to carry that.
    #907665
    sergius
    I carry:
    I carry:
    – Two tubes (after “the” incident)
    – Tyre levers
    – Multi-tool
    – Tyre boots/self-adhesive puncture repair patches
    – A valve core tool (again, after “the” incident)
    Everything is stored in freezer bags for easy packing and waterproofing (plus a silica gel packet in with the multi-tool)
    I currently use a Topeak one which is the best of the many I’ve tried.  Quick release from the saddle, expandable if needed and has a loop for a light when the light isn’t so good.
    I hate the asthetics of saddle bags – but I’m not prepared to fill up my jersey with tools.  It’s already got enough in it with phone + food.
    #907663
    Sevenfold
    I prefer to have as much as I
    I prefer to have as much as I can in my saddlebag so I can leave my jersey pockets for food. So I carry 2 inner tubes, CO2 + 2 spare cartridgers, multi-tool, 2 large tyre levers, patch kit & spare chain links, packaway jacket & a couple of cable ties. The Topeak bag I currently use is quick release & expandable (great idea & worth incorporating in your design) but no longer made which is a shame as mine is 7 years old & starting to show its age. Each bike I have has the same quick release on the saddle rails so it is easy to move from bike to bike. I’ll second the loop for a rear light.
    #907661
    Welsh boy
    I think you are trying to get
    I think you are trying to get too much in there.  If you only have 2 CO2 canisters anything more than 2 tubes (your patch kit) is pointless and personally I think multi tools are a waste of time, carry a 4mm, 5mm and 5mm allen key, that is enough for most roadside repairs.  I carry my stuff in a medium size bottle box which means i can also carry a small pump for those emergencies where you run out of CO2.
    In answer to your question, I dont like velco fasteners around a seatpost, i have ruined an ecpensive pair of leggings in one ride where the velcro rubbed against my leg so i would like to see some form of saddle mounted bracket so it is easy to swap the saddle pack between bikes, something like Topeak use.  It must also have a loop for a rear light which doesn’t leave your light pointing down at the floor like so many do.
