- This topic has 10 replies, 10 voices, and was last updated 8 years, 11 months ago by .
Hello all,
Could I please ask for some opinion/advice wrt these boots in particular, and other brands?
I thought this was quite a considered purchase given all the research I had done, but today after a 3 hour ride in mainly very heavy rain I have returned with wet feet. From how the boots felt on the ride, and from feeling around inside, the wet seems to be concentrated where the cleat and studs are located, but I thought that the construction of these boots prevented ingress at those points?. I don’t think that a lot of water has come down from the top as I had a pair of Amfib tights on.
I noticed the wet and cold soles around 1.5 hours into the ride. When I took the boots off my feet were not soaking, just the soles were wet. Am I expecting too much wrt totally dry soles? I appreciate that leakage from the top may well happen in extreme conditions.
Has anyone tried the Fizik X5’s? I need a warm, waterproof boot that is Atac/SPD compatible. I’ve not had the Northwave boots long, so may be able to return them.
Thanks in advance, Andrew.
